Old 13th November 2006, 19:48
jeremy jeremy is offline
jeremy is on a distinguished road
Default wheels
Could all you e30 builders give some info about the size of rims and tyres used and rear spacers needed to fill the arches fully? Cheers
Old 14th November 2006, 12:29
Patrick's Avatar
Patrick Patrick is offline
We're using:
205/65/R15 on a 15x7J rim - the tyre side wall size is bigger than the standard E30 - they are the same size as you find on E36's. I don't recall the offset at the moment, I would have to check that.
The has 30mm spacers per side - these are H&R from www.performancealloys.com - could probably have gone with 35mm per side.
Old 14th November 2006, 13:21
Default wheels
Thanks Patrick, I cant remember whether I have the wide arch wings or standard>Could you measure your widest part of front and rear wing? Thanks
