Old 23rd September 2006, 19:07
MartinClan's Avatar
Default Pedal Box
I am just making the final touches to my pedal box (mainly with a big hammer on the brake pedal lol) Has anyone fiitted a return spring to the brake pedal? Marlin don't mention this but it seems to be normal practicse. I assume that it just ensures there is no load on the servo when the brakes are "off".
Old 25th September 2006, 20:45
peterux's Avatar
peterux peterux is offline
Robin, I think I did, but can't remember how? I'll try and take a picture next time I'm down at the lock-up.
Old 25th September 2006, 21:02
MartinClan's Avatar
Ok Peter - thanks
Old 26th September 2006, 14:00
Patrick's Avatar
Patrick Patrick is offline
I hadn't planned to, but I have saved all the springs from the donor if its a good idea.
I had to move my brake pedal quite a lot to make room for my feet! It used to be straight:
Im thinking about adding thicker metal to the side where the clutch is as this seems to move alot when using the clutch.
Old 1st October 2006, 20:54
peterux's Avatar
OK, so I popped along to the lock up today.
Cranked my head under the steering column. No sign of any spring on the brake pedal. It seems that the "return" spring on the servo is sufficient to hold the pedal back.
However, I did fit a spring on the clutch pedal.
i'll try and post a picture later.....
Old 1st October 2006, 21:16
peterux's Avatar
Still haven't figured out how to post a picture, so I have put a few on my Flickr site....
http://www.flickr.com/photos/peters-bmwmarlin/
hope this helps?
Old 2nd October 2006, 07:48
MartinClan's Avatar
Hello Peter
Thanks for that. Did you also put a spring on the brake pedal?
Regards
Old 2nd October 2006, 08:18
Patrick's Avatar
This is the code you need:
[img]http://static.flickr.com/99/257787646_9c0498716f.jpg[/img]
Which results in:
Might get a "no hot linking" image though.
Old 2nd October 2006, 20:16
peterux's Avatar
thanks
