Old 1st September 2006, 11:23
jeremy jeremy is offline
jeremy is on a distinguished road
Default clocks and dash board
Has anybody used different clocks to marlins? has anybody pictures of their dash layout they could send me? Alsointerested in using a push button start; any ideas? Cheers
Old 1st September 2006, 12:27
MartinClan's Avatar
Push button start very simple to rig - you just need to disconnect the wires that go to the starter solenoid from the ignition switch and connect them to your push button instaed. You need to keep the ignition switch as the SVA require it as an anti theft device - you just won't use the sprung position that starts the engine.
Old 1st September 2006, 15:11
Thanks for that.Did u use a 2 or 3 turn ignition switch?
Old 5th September 2006, 20:13
MartinClan's Avatar
My ignition switch has two positions plus the sprung third for operating the started motor.
