Old 20th July 2006, 17:28
bigrich's Avatar
bigrich bigrich is offline
Default High Level Brake Light
Hi...
Not sure on this one......Marlin supply a high level centre brake light in the kit. I don't want to position it in the engine vent cover as they have...in fact I don't want it at all.
But, will it pass SVA without?
Anyone know?
Rich
Old 21st July 2006, 14:43
Default Eye Level
Well Rich it depends who is doing the SVA.
After reading of the problems that MarlinTurbo had down West, with his lights failing due to the recess I cut mine into the rear of the car a'la Boxer and the examiner made no comment at all.
If I were you I would play it safe and use it even if it's only a temporary fitting.
Regards Trev
Old 21st July 2006, 17:09
Patrick's Avatar
Patrick Patrick is offline
I dont think the 3rd break light is needed for SVA, the Sportsters dont have them and pass just fine
Old 22nd July 2006, 09:06
limpabit's Avatar
limpabit limpabit is offline
No need for a third stop lamp.
But you will need to meet the following for Stop lamps.
Angle of visibility:
a Horizontal:- 45 degrees inwards and outwards
b Vertical:-
1) <1500mm above the ground - 15 degrees above and 10 degrees below Horizontal.
2) <750mm above ground - 15 degrees above and 5 degrees below horizontal.
3) otherwise 15 degrees above and below horizontal.
Looking at marlins and speaking to Mark, they used a foam spacer to extand the light out. But not sure if this was the brake light.
