Old 14th April 2018, 07:39
blinkey501 blinkey501 is offline
blinkey501 is on a distinguished road
Default Hello information required
Firstly I would like to introduce myself.
I am a 46-year-old engineer that started work life as a fabrication welder in a family business after leaving school 30 years ago. I also at that time started out on a four-year apprenticeship.
I am mad about motorbikes and a general petrol head and have love of all things mechanical.
I have also done a lot of oval circuit racing which was none contact and full contact.
The reason why I ended up here.
I have a car that has been owned since it as three years old that is front wheel drive, I would like to convert this car to a track car. I also would like to convert it to run a motorbike engine and I am looking at using either a GSXR1000 motor or possibly a Rotax v twin from an Aprilia RSV Mille which I already have.
I am not sure if it is possible to use the original gearbox from the car and marry the output shaft off that holds the sprocket on the motorbike engine to the input shaft the holds the clutch to the gearbox on the car.
I am looking for advice to see if anyone has done this?
I can make an adapter plate to bolt the bike engine to the bell housing of the gearbox.
Or.
Secondly, would people suggest this is not a good idea?
Would it be easier to use constant velocity joints and use a chain and sprocket configuration to connect the shaft to the original gearbox input shaft?
Or.
Thirdly start with a different idea altogether?
I am very opened minded and any help would be appreciated. Thank you.
Old 14th April 2018, 13:39
redratbike's Avatar
Watch out a lunatic Aprilia owner
Hi Blinkey what’s the car?
Old 14th April 2018, 15:12
If the car you have is small and light you will be in with a chance. Most bike engine swops I have seen use the bike gearbox as its all part of the same casting as the engine. Take a look at all the Autograss class 5 and 7's with bike engines fitted. Also see the Z Cars Mini conversions ask, for Chris Alinson I think his name is.
Old 14th April 2018, 19:29
redratbike's Avatar
Blinkey
Check this out for ideas
http://www.pro-motive.co.uk
Old 15th April 2018, 06:14
Well hello sailor. Can't hide from anyone on the net lol.
Its a Peugeot 206. But interior etc will be fully stripped for weight saving etc. The external fuel tank will be removed also and an internal aluminium tank fitted inside the back.
Old 15th April 2018, 06:16
I thought about going to look at an autograss meet to see what they had dione tbh.
But thanks for the heads up fella.
Old 15th April 2018, 06:38
Blinkey501 - Welcome to the forum.
...Most bike engine swops I have seen use the bike gearbox as its all part of the same casting as the engine...
This is the key point and usually give the car 'sequential' gear shift, back for 1st, then forward for 2nd to 5th/6th.
( Reverse is often an issue for bike engine cars. )
These 'Legend' race series cars use bike engines, so check these out too.
Old 15th April 2018, 06:43
Yes, I have seen them too. It seems there is a lot of cars in different variant are using this setup. Thanks.
