Seven Style builds Westfields, Caterham, Dax Rush, Luego, Robin Hood, Tiger, Locust, MK, RAW, Quantum, you name it, you're building it, share it here. |
11th November 2017, 23:52
Identify Kit Car
Hi guys - I was looking at the car attached. Can you Identify it - Is is a Champion with a slightly modified chassis?
12th November 2017, 00:13
Appears to be a McSorley 4-4-2 chassis from plans that Jim McSorley has posted on locostusa.net. (4-4-2 is, in inches, longer, wider, taller).
12th November 2017, 00:32
I assume it would not take standard haynes or Champion grp panels- can the panels be got in UK
12th November 2017, 00:55
One would have to modify the Champion panels, not too difficult.
12th November 2017, 08:40
Just buy one of the hsr Austin 3000 kit car bodies from eBay and have something different
12th November 2017, 22:04
McSorley 442
How would you identify the chassis as Mcsorley - I though it looked the same as a champion only bigger. What would you look out for?
12th November 2017, 23:38
Additional chassis tubes. Send me an e-mail and I'll attach the plans. Jim did a finite analysis and added, eliminated and otherwise improved the "book" chassis.
jmolleur@cfl.rr.com
13th November 2017, 09:15
McSorley
Thanks, I have seen the drawings but looking at the pictures was not able to tell. Is there any obvious differences? Also IS the Mcsorley based on the Champion not the Gibbs chassis?
13th November 2017, 12:18
Jim based it on the Champion "book" frame. Yes, was difficult to see in the post. The front triangulation of tubes was a hint. It may not be a McSorley,
but a homespun similar design.
