Old 15th April 2016, 19:03
Nubodi Automotive's Avatar
Nubodi Automotive Nubodi Automotive is offline
Default NUBODI AUTOMOTIVE - 250 replica exhaust
I have been thinking about replicating the exhaust fitted to the Ferrari 250’s for a while but could not find the right parts.
Old 15th April 2016, 19:09
I can buy them new for around £2500(!)This is what they look like.
Old 15th April 2016, 19:10
This is the exhaust I made a year ago which was more inspired by a Daytona but has served me well although too quiet.
Old 15th April 2016, 19:11
Eventually after buying different tailpipes the correct ones came. So I purchased three more. These are approx the right shape and are double skinned which as you will see is important. I bought some 1” 304 grade stainless strip and chopped it into 24 squares. I rounded off the corners for a better look. I found some Y-sections in 304 stainless and some 2” tubes which were cut into four.
Old 15th April 2016, 19:12
There is a distinctive shape in the side of the tailpipe which I wanted to cut out. I used a Dremel with a stainless cutting disc. It looks easy but is in fact very difficult to do with a grinder. The first two attempts were not perfect so they will go on the inside. The next two were better.
Old 15th April 2016, 19:13
Old 15th April 2016, 19:15
I used a rotary burr to clean up the edges. All the parts needed were assembled and off I went to Longlife in Basingstoke to see Matt who is a fantastic TIG welder. He was very hesitant when I asked him what I wanted him to make for me. I convinced him he could do it and off we went. I measured the circumference of the straight tubes and made 6 lines on each. Matt welded the squares onto the end...all 24 of them! He then made up two reducers with his magic pipe spreader which bridged the gap from the Y section to the 2 ½” bore of the tailpipes. He then welded it all together.
Old 15th April 2016, 19:16
Old 15th April 2016, 19:17
The old exhaust was removed and the BMW exhaust cut where he needed it. The 3.0 has two pipe outlets whereas most of the 2.8’s have one. So two separate pipes were bent and attached to the front outlets. He then tack welded the tailpipe assemblies to the pipes. I attached the exhaust rubber bobbins and he welded on a support bracket for each. The system was removed and seam welded.
Old 15th April 2016, 19:18
A centre support was welded onto the left pipe and secured with the original Z3 rubber mount. The two centre pipes were joined by a rather nice bar bracket. I have to paint inside the side shape, the exhaust inners and the end bracket in heat resistant matt black paint yet but you get the idea. So the moment of truth arrived. Removing 4 silencers did the trick...it’s loud enough now but has a very deep growl with endless popping and crackling on the overrun. I would even say I prefer the sound to the original Ferrari. Perfect. Very happy customer. So the cost of all this? Remember the tailpipes took three hours to make and two more hours to finish the whole system. This system in future will cost you £585. You will have to wait four weeks though as Matt is in great demand, but worth every penny. Come and see it / hear it at Stoneleigh 2016.
Old 15th April 2016, 19:20
I'll post some pics of the finished system when it finally stops raining.
Old 15th April 2016, 19:22
Abarth do suitable tail pipes -
http://www.ebay.co.uk/itm/Jaguar-E-t...cAAOSwT4lWTMJk
I believe Ansa also do something similar.
Not sure if either company has UK suppliers. If not, you could always contact them about UK distribution rights and becoming their agent. So long as we're still in the EU of course...
N.B. sorry if this post seems a bit thread jacky but when I submitted it for some reason the only post showing on my computer was the first entry which just says ... I can't find the right parts... Once I clicked 'post reply' the rest of the thread appeared.
Old 15th April 2016, 19:25
These are like the ones I took off though not 250 style..the Ansa ones are a fortune as well, I have them on my Daytona.
I had to tell the wife I got lost on the way home...I did not want to get out of the car. This is going to cost me a fortune in extra fuel.
Old 15th April 2016, 19:59
He did a nice job.
I made something similar myself on Alex's GTO that we build a while back:
Clamps showing were removed after some additional welding.
Old 15th April 2016, 20:24
smash smash is offline
Originally Posted by Nubodi Automotive View Post
Blimey what caliber are they?! They're huge! You'll be well received down the sea front if you ever come to Essex
Old 15th April 2016, 20:42
Roadster's Avatar
Roadster Roadster is offline
http://www.ebay.co.uk/itm/Red-Blue-S...kAAOSwAvJW~uFU
These look similar budget versions are available
Old 16th April 2016, 08:03
They are actually only 1/2 inch bigger than the originals, its not the best picture (makes them look bigger) but its still b****y raining.
Old 16th April 2016, 08:23
COOL LOOKING PIPES EVERYONE ...Nice find Roadster ..they will work very nicely for someone on a budget ...
Old 16th April 2016, 08:47
kevemm kevemm is offline
kevemm is on a distinguished road
Rich they do look good look forward to the full pictures and sound once that flippin rain stops!
Old 16th April 2016, 09:10
NeilF355 NeilF355 is offline
Might as well add a picture of mine!
