Old 6th March 2006, 17:14
paul sullivan paul sullivan is offline
paul sullivan is on a distinguished road
Default rear fog light switch, hazard switch
Hi guys. I seem to be having a problem getting the Rover switches to work.
Would i be right in saying that more simple type switches are needed.
The Rover switches are wired through the red ecu under the dash. We obviously don't have this with the Marlin loom and i'm begining to believe it would have been better to use the donor loom.
By the way, I'm still having trouble wiring the 5as unit.
HELP HELP HELP
Paul
Old 7th March 2006, 07:12
limpabit's Avatar
limpabit limpabit is offline
In the process of doing mine. So would love to hear as well re the hazard and fog light.
Old 7th March 2006, 08:37
limpabit's Avatar
Ok looking at the circuit diagram for the rear fogs, the multifunction unit acts as a relay.
So I would have thought something like this:
But maybe worth checking with Marlin to see how they done there's.
Old 8th March 2006, 16:45
limpabit's Avatar
I think I may have got to the bottom of the hazard problem. But need to get it verified by Marlin. Just to make sure.
What do you guys think? Does this look right?
Old 8th March 2006, 19:04
I am in your debt.
I'll have a go at this also
Paul
Old 8th March 2006, 21:07
limpabit's Avatar
Don't forget. This is my guess.
I'll verify by Marlin or test and see.
Old 9th March 2006, 16:03
limpabit's Avatar
Ah the hazards.
Connected up today. The hazards kind of work (well dash flashes anyway ). It will only flash when the ignition switch is on. I remember the which kit guy having the same problem and swapping a wire so it comes on all the time.
Connected the lg/k to the green on the hazard switch. Hazard's now work all ok. But fires engine management etc. (due to being connected to the green)
Will investigate further.
Old 9th March 2006, 18:08
tony-g tony-g is offline
hi all
If anyone is interested i wired mine up using a normal push button switch as i wanted it to fit in with the rest if the neon blue switches i have fitted. If anybody is interested i will dig out the wiring diagram i made up at the time but you would have to source to diodes to put in the circuit so that it will work with and without the ignition on.
all the best
tony g
Old 10th March 2006, 08:29
limpabit's Avatar
Found the problem. After reading Which kit all became clear. There's a wiring fault in the Marlin loom. So the green from the flasher relay needs cutting and routed to the LG/K. Diagram above updated. All works as it should.
HTH
Old 17th January 2016, 21:31
bigrich's Avatar
bigrich bigrich is offline
Default wiring diagram
Alex, try this diagram....
Rich
