Old 6th June 2014, 08:33
Default Rear lights
What a great set of lights!
Old 6th June 2014, 09:01
IanA's Avatar
IanA IanA is offline
I have similar from MCP in Bilston referred to as L448 lights- presumably from an early Landie. Not sure how they will sit on a curved surface so have made neoprene spacers to sit between.
Old 6th June 2014, 12:20
Thes are definitely not land rover, a lot more period than those cheap plastic things (also seen on the early Daleks!)
Old 6th June 2014, 13:12
IanA's Avatar
I said "early" Landie - no plastic involved. Otherwise they might just as well be Hillman Imp !!!
Do you have the eBay link available?
Old 6th June 2014, 15:37
I had a series 1 landy, they had no indicators, glass sidelights and a bespoke rear light in glass as well. Trafficators were an option, great fun but nobody ever noticed them in traffic.
http://www.carbuildersolutions.com/u...lamps-set-of-6
This is a link to the picture I posted, if I hadn't already cut holes out I would be buying them
Old 6th June 2014, 16:02
IanA's Avatar
Yes they are very nice. I'd still have issues with them fitting a curved surface, and the mounting holes are very close to the large aperture required.
These are the plasticky ones that MCP had at Stoneleigh:
and these flat profile glass ones are what I have now:
Old 6th June 2014, 18:04
They look good too. I can see the challenge in mounting them on a curved surface...
Old 6th June 2014, 19:54
Frenched in lights - you know retro is the future
Old 8th June 2014, 18:53
IanA's Avatar
Yes, once the final positions are decided, I expect to add thickness to the inside of the shell and sand some round flats for them on the outside.
