Old 20th November 2005, 20:49
peterux's Avatar
peterux peterux is offline
Default Engine mounting bracket bolts
Here's a little tip to other BMW Sportster builders.
The Marlin supplied engine mounting brackets are much thinner than the orginal BMW alloy ones, so you need to use shorter bolts.
I thought I'd use the originals which, as I tightened them up, hit the bottom of the tapped hole in the engine block.
I foolishly snapped one off in the block today !
Now i'll have to spend time extracting it before I move on!
best regards to other builders,
Old 21st November 2005, 12:50
Patrick's Avatar
Patrick Patrick is offline
Good tip!
I've been replacing bolts as I go so I didnt run into this one - I order the big selection pack from http://www.namrick.co.uk/ (and then a second one later)
