Old 25th August 2012, 16:34
MoriniMan's Avatar
MoriniMan MoriniMan is offline
MoriniMan is on a distinguished road
Default Paul's Mazda Sammio
I'll try and remember to post progress here in future!
I made a pair of engine mounting plate templates late this morning.
After a bit of lunch I fired up the bandsaw and cut them out of 3/16" mild steel plate, drilled the holes and cleaned up the profile on the linisher.
Next job will be to make the templates for the actual brackets. I'm using a pair of Landrover V8 mounting rubbers. They're cheap and know to work with this engine (not too much vibration).
The original inlet manifold is a huge heavy affair, so it has to go. One solution is to cut off the original flanges
and fabricate a plenum chamber with the single original throttle body on the end. Something like this;
The other solution is to use individual throttle bodies. These are off a Triumph Daytona motorcycle. They can be unbolted from each other and re-spaced to suit the Mazda inlet ports.
There are pros and cons to each approach. I'm leaving my options open at the moment. Using motorcycle fuel injection throttle bodies along with a Megasquirt ECU (from a kit or ready built) to upgrade an old engine (or a newer one) is within the reach of many DIYers and there's an active support forum.
I found a pair of 3" Aston filler caps on ebay for £40. They'll clean up quite nicely, but with a bit of patina, rather than too shiny new.
Old 25th August 2012, 17:06
Wow, is there anything you won't slice in two with a band saw and modify?
I'm really looking forward to seeing your build progress as you clearly know what you're doing, which is more than I can say for myself at the moment as the electrics I'd sorted now refuse to play ball. Hey ho, back to the drawing board.
Old 26th August 2012, 19:18
MoriniMan's Avatar
Yes, ME!
Old 26th August 2012, 19:34
Originally Posted by MoriniMan View Post
Yes, ME!
Well, I'm sure it would work for Damien Hirst or Tracey Emin. Or that German chap that pickles dead bodies in aspic or something...
Old 1st March 2013, 09:34
AndyP57's Avatar
AndyP57 AndyP57 is offline
Hi Paul. You've been very quiet of late. How are things?
Old 1st March 2013, 12:29
MoriniMan's Avatar
Quiet?
Virtually silent! (for once)
No progress over winter. IBS related chronic fatige with a dose of SAD on top is a bastard.
I did do some work on other people's stuff and now that 2 Ton of spare milling machine had gone off to Scotland I'm re-arranging the workshop. Then I should be able to put some of the motorcycles into the lean-to and bring the rolling chassis in. Then I might be able to make some real progress on the body frame.
Not been vising the forum much, so I hope everybody's build is going well.
