12th April 2010, 21:00
Wheels, again!
My better half keeps banging on about the Sportster needing a set of wire wheels!!
I didn't think that was possible, until I curiously did a bit of googling...
I came across these and wondered if anyone has an experience of this type of wheel.
http://www.mwsint.com/Shop/Details.asp?Id=XW711_2#
The BMW e30 is not listed but these have the right PCD. Not so sure about the offset and rear clearance as they seem to use an un-conventional terminology.
I bet they are devils to keep clean, but....
12th April 2010, 21:37
Yes, wires would look nice - I looked into it some time ago, and I found a German company that did them. Patrick deciphered the site and sent them an email for me, but I don't think they ever got back to us.
What was good about them was they machined bolt on splines, so you had proper knock off spinners on the wheels for a nice old fashioned look.
http://www.madabout-kitcars.com/foru...ht=wire+wheels
http://shop.showtime-hydraulics.de//...641714b3321766
12th April 2010, 21:51
Thanks, I'd forgotten all about that thread! (And being a bit lazy didn't do a search)
They do look nice, but do they last well and could I live with all the cleaning??
Also, a very expensive luxury! Maybe I can find a aBay supplier in China!
Time for a re-think....
...peter
BTW have you had the Gooster out of her nest again?
13th April 2010, 07:50
I have a photo of a Berlinetta with wire wheels from MWSint, which I plan to put on my Cabrio............... (but only when I get her fully registered -I have to try to dangle carrotts to my self to make me get on with it!!)
http://www.flickr.com/photos/mikes_bmw_marlin_cabrio/
13th April 2010, 08:01
Looks good, but what hubs does that Berli have? I bet they're not BMW. Whilst MWS do a 4 x 100 PCD bolt pattern, what about the central bore? Their site doesn't offer anything specifically for a BMW when you do a search.
13th April 2010, 08:07
Actually, they do undrilled bolt on splines:
http://www.mwsint.com/Shop/Details.asp?Id=RSK365
So you could get them custom drilled to fit the beemer hubs and the get some proper centre lock wheels. More expensive, but they'd look brilliant.
13th April 2010, 21:04
Originally Posted by Mike
Oooh, the look the dogs dangly bits!
13th April 2010, 21:06
Yes, I noticed that. I'm tempted to give them a call but not untill I'm sure I really want to spend that much money!
14th April 2010, 10:14
Another source?
http://www.daytonwirewheels.com/wirewheels.html
I've emailed them for details on fittment availability and wether or not they have a european distributor.
14th April 2010, 10:39
You guys must be bonkers. Rather than driving your cars you will spend the rest of your lives cleaning spokes.
14th April 2010, 13:29
14th April 2010, 21:39
That's what I've been worrying about.... (and the price!)
Maybe these are a better compromise?
http://www.alloywheels.com/product.a...Keywords=4x100 et15,4x100 et20,4x100 et25&numPageStartPosition=8&strSearchCriteria=any& PT_ID=all&strSort=Low&Make=BMW&Model=3 Series E30&strSize=15"&searchSize=15"
15th April 2010, 07:25
That's essentially what Patrick and I have (albiet not split rims).
Take a look on eBay for 15" BMW BBS Crossweaves. I got all 5 of mine for about £150 and then had them professionally refinished. In all, I got all of them for under £500 with the powdercoating, they look the part for now and they fit the hubs perfectly.
http://www.greatoldone.co.uk/Gooster..._Wheels_2.html
16th April 2010, 07:41
A reply from Dayton Wheels...
Here's what I asked:
Hi - I have a Marlin Sportster Kit-Car:
http://www.marlinsportscars.co.uk/sportster/
Which is based on an e30 BMW 325i. Do you do either:
- bolt on wire wheels which would fit the e30 hubs? They have a 4 x
100mm PCD, and a centre bore of 57.1mm.
- bolt on splines that would fit those hubs?
Finally - do you have a European / UK distributor?
Many thanks
Jason Cundall
Here's the reply
Originally Posted by Jim Good @ Dayton
Jason,
Fitting the 325i should not be an issue but with the replica kit on it I
am unsure of the clearances. If you can fill out the attached I would be
able to get a better idea of what will or will not work for you.
Jim
He's sent a form to be filled in with measurements around the hub and caliper etc, so I may fill it in at the weekend to see exactly how big a heart attack I'll have from the price... Sticker Shock, I believe our colonial cousins call it.
