Old 30th May 2009, 19:46
mynameisjon21 mynameisjon21 is offline
mynameisjon21 is on a distinguished road
Default No spark :(
Hello
I am trying to get my engine to start for the first time in years.(its a kit hence the long period of time)
It is a 1.6 sierra ohc.(Creg)
My main problem is that i have no spark
I have put new Spark plugs, HT leads, Dizzy cap, rotor arm, ignition module(amp) and a new ignition coil on and still no spark
Ive cut out the suppressor, the rotor arm spins when starting and it doesnt have a alarm etc on.
Ive cleaned the ignition trigger (well kind of lol but i do get an ohm reading through it)
at the ignition coil when the ignition is on i get 12v from the black wire (+side) and only 3 from the (2)green wires (-side) i get 12v from the ht lead goin to the dizzy cap but when i put a electric test on rather then the multimeter the bulb doesnt light up.
so if i havent baffled you with my problem or bad explanation pleasssseeee help
Any help would be much appreciated
Jon
Old 2nd June 2009, 13:29
eaa53's Avatar
eaa53 eaa53 is offline
Default Sorted Yet?
Jon
Are you sorted yet?
If not I will check out my systems and my build drawings to compare notes to see if you are wired the same and me.
I recall finding a wiring diagram that I worked too and all was well after a double green issue and some head scratching.
The dizzy and the spark plugs are only an issue if you have the triggered pulse to the coil, if you 'aint got the pulse to the coil everything else is just there for show.
Concentrate on the pickup and amp to coil signals, once that's working the rest should work.
eaa53
Old 4th June 2009, 16:28
no still havent got this sorted yet :-(
that wiring diagram could be very handy cos i have the double green wire thing too, how did you sort that?
Cheers Mate
Jon
Old 6th June 2009, 19:24
Default purrrrr
I got her running it was the wire from the ignition trigger thingy mijig to the ignition coil :-) she runs like a dream too a couple of things to finish an IVA test (boooo) and im on the road
Cheers for the help
Jon
Old 7th June 2009, 18:43
eaa53's Avatar
Jon
Pleased to hear you sorted it. I had just photographed the loom and found the diagram but you are sorted so no need to upload them for you.
I was on a track day on Saturday but had to finish early due to a seized clutch cable.
Got a few good laps in before the probelm stopped me.
Hope you enjoy your car as much.
JohnC
Old 24th September 2009, 13:24
ysabel ysabel is offline
ysabel is on a distinguished road
check your wirings and your battery, this might the problem.
