Old 19th February 2009, 18:32
bigrich's Avatar
bigrich bigrich is offline
Smile Rover 1.8t Kseries & R65 gearbox??
Hi,
I was wondering about 'simple' power improvements...and considered how this could work with a standard 1.6 R65 (cable operated clutch)gearbox.
...so does anyone know if teh 1.8t hooked up to a standard R65 gearbox and cable operated clutch would hold up?.....or is it just going to disintegrate.
Old 20th February 2009, 07:15
most of the rover gearboxes are not rated for high torque, the PG1 being the strongest although the "uprated" PG1 for the R220 turbo was still only rated for 175lbft! so wacking a turbo k-series onto anything other than an uprated PG1 would probably be asking for trouble.
I have a spare standard k-series 1.8 PG1 for sale which would need uprated bearings to handle high torque
Old 20th February 2009, 11:57
limpabit's Avatar
limpabit limpabit is offline
I'm with Chris on this one Rich. I don't think a standard R65 would handle that power very good. Then there's an uprated clutch you would need I would have thought.
Old 20th February 2009, 12:30
DavidH DavidH is offline
I know people who have used the r65 with the 1.8mpi and VVC in GTM's and in Talons you need to swap the flywheel on the engine to the one from the 1.6 but they have not had any other problems. But obviously it will put more stain on the box, guess the reason you are thinking of it over the PG1 is you wont need new mounts.
D.
Old 20th February 2009, 12:41
limpabit's Avatar
And gear change and clutch cables will be the same.
There's some info on the R65 gearbox here:
http://www.rovertech.net/forum/viewt...hp?f=4&t=99452
hth
