Old 14th August 2008, 09:06
Tim Russell's Avatar
Tim Russell Tim Russell is offline
Tim Russell is on a distinguished road
Question Clunk from rear suspension
I'm currently finishing off the build of my Edge Sportscars Devil and I have a problem.
On the rear right hand suspension we have an almighty clunk when we roll the car backwards or forwards. If I roll the car forwards, I hear the clunk once, and then not again until I roll the car backwards. Then once again I hear it once and then it's gone.
I have removed the driveshaft from the gearbox to eliminate that and the sound stays. I have placed my hand on several components around the rear suspension, and the clunk feels loudest (Yeah that is what i mean ) when I have my hand on the hub carrier.
Things I have done:
Remove complete suspension and place the hub carrier in the vice. I then used a bolt and bog washers to pre-load the bearing and checked for noises: Result none.
I have also remove the driveshaft with CV's (Non serviceable CV) and checked for free play / strange noises: result none.
Over the last few days I have had number of people round from the local kit car club and we are all stumped. There is no physical movement visable, but we do get a loud clunk.
Anyone here got any ideas?
Rear wheel bearing btw is a sealed Audi thing that is pushed into the housing and onto the drive flange with a press.
Old 14th August 2008, 17:38
limpabit's Avatar
limpabit limpabit is offline
Not the balljoints???
Old 14th August 2008, 20:11
peterux's Avatar
peterux peterux is offline
Brake pads or handbrake pads catching?
Wheel studs catching on caliper?
Old 14th August 2008, 20:45
Patrick's Avatar
Patrick Patrick is offline
Or brake calliper.
My front left calliper clunks because the spring on the pad has disappeared.
Old 15th August 2008, 06:52
Red face Click update
Thanks for the responses.
Last night I removed all unnecessary parts from the suspension (Brakes, cycle wing supports etc) so I only had top arm, bottom arm, shock and track control arm. The click was still there.
After this I changed the rose joints on all three points to make the track as narrow as possible, click was still there. I then extended all of the rose joints to give maximum track width, click got worse!
Last thing I did was wind the track control arm in and adjust the toe in/out. Click disappeared!
I don't have any measurement equipment except for the most basic so I can only assume that my wheel alignment was so far out I was loading the suspension up and the tire was skipping... Whadya think?
Old 15th August 2008, 10:12
Patrick's Avatar
sounds like slop some where in the track control arm when it is extended. See if you can see / measure any wobble when the thread is extended would be my next move
