26th January 2007, 15:35
Spacer for master cylinder push rod
Message for Patrick - I have made a drawing and I should have a couple of spacers made up by next week. I assume you still want one?
Picture here http://myweb.tiscali.co.uk/martinclan/images/spacer.gif
26th January 2007, 21:21
Looks good and yes please
28th January 2007, 10:50
This is exactlly whay i made up myself out of some 10mm stainless bar and it works a treat.
Stuart
29th January 2007, 12:58
Robin, thinking about it. I should be able to make that on the lathe.
EDIT: I'd have to source the material and do some testing first
29th January 2007, 14:11
Hi Patrick
The guy is making them today or tomorrow - will be £5. (Everything is in £5 increments that he does lol)
I need to know ASAP if you don't want one!
29th January 2007, 14:16
That's OK I still want one I was more thinking out loud really.
11th February 2007, 16:23
Patrick
Have chased up the guy that is making them and should have them next week.
11th February 2007, 16:37
Thanks Robin
18th February 2007, 21:34
Robin,
Here's mine after a bit of extra work on the lathe - works really well like this:
I used that bolt that I put in the master cylinder with silicone as a master to shape the metal pin. It's not spot on but it should fit nicely.
19th February 2007, 07:38
Mine ended up about the same shape through trial and error. Had to drill the hole slightly deeper also but seems to be a good fit now with just a few mm travel on the brake pedal before the piston in the master cylinder begins to move.
24th February 2007, 18:58
Robin we bled the brakes today and went for a short run down the drive way and back, they work very well with almost instant braking as soon as you move the pedal - 100% success Thank you again.
