Old 30th June 2018, 18:19
zxrjon zxrjon is offline
zxrjon is on a distinguished road
Default best glue for panels?
what is the best adhesive for bonding fibreglass to painted steel?
i'm guessing a PU adhesive, but what is the thoughts of the experienced?
Old 30th June 2018, 20:06
phil.coyle phil.coyle is offline
phil.coyle is on a distinguished road
checkout Sikaflex adhesives, but be warned once it sets that's it.
I used it to bond my aluminium transmission tunnel, tried to take apart a few years later , forget it!
Phil
Old 30th June 2018, 20:35
Thanks Phil.
I've been looking at Sikaflex, Tiger Seal and Tetrasol.
I'm sure they're pretty much of a muchness but like the opinions of those who've used them.
Old 1st July 2018, 15:22
I've used one called Fixall from toolstation - seems every bit as good as the branded ones at a fraction of the price.
Old 1st July 2018, 17:55
ZXRJon – I used a general purpose bonding paste from Glasplies:
http://www.glasplies.co.uk/2-5-Kg-Bo...white2.5kg.htm
This required a catalyst and starts off blue.
Then, before it starts to set fully, it goes brown.
I actually came across my test piece the other day…
( Box section steel and fibreglass. )
Three years on and it is still as solid as a rock.
Hope that helps, Paul.
Old 2nd July 2018, 19:50
I've used PU18 which is designed for automotive / marine and industrial use. Very strong bond for most applications. I usually buy it through ebay sellers for about £4 per tube, it goes along way too.
With Sikaflex there are more than one type. The stuff sold through places such as Screw Fix is the cheaper DIY version which has lots of "filler" in it and less bonding material so its not as strong as the professional version.
Old 8th July 2018, 21:12
Thank you for the replies.
I'm going for the Glasplies stuff recommended by Paul.
They'll be a few bits that will be Sikaflex bonded too.
