Old 14th May 2016, 13:52
Default Sammio #47 feature
Not sure if this has been posted before but I found this whilst googling ..
Decent article with some great pics of one of my favourite examples ...
http://autovisie.nl/2016/03/vintage/...vijftig-racer/
Old 14th May 2016, 17:11
phil9 phil9 is offline
great car ..me and towed was talking about it to day .......
Old 14th May 2016, 18:13
swifty's Avatar
swifty swifty is offline
Yep, this is one of my favorite cars as well.
Old 15th May 2016, 08:27
Marc F Marc F is offline
That is incredibly well done isn't it
Old 15th May 2016, 09:12
IT HAS SOME REALLY NICE TOUCHES ...The interior is very Maserati ish with the small tubing , I really like that.
Colour and graphics work brilliantly on it too ..
The photos are just great ...
Old 16th May 2016, 07:36
Jerome Jerome is offline
Jerome is on a distinguished road
Lancelot:thank you,it was my son who made the photo,s!
he is working for äuto-visie".
Old 16th May 2016, 07:39
DaveP DaveP is offline
They are very good indeed. Love the shots when it is on the move - excellent work.
Old 16th May 2016, 08:44
Here are more (and better) photos from my son of this Sammio!
http://www.jeromewassenaar.nl/?portfolio=sammio-spyder
Old 16th May 2016, 15:23
Superb pictures Jerome. Where did you get that tachometer? I really like it.
Old 19th May 2016, 16:57
Mister Towed it isn,t my car, but I think it was a rather expensive rebuild(electronic)tacho from an Italian? car.
I have a question:i,am struggling with my Stromberg CD150 carbs,do the CD175 types just fit on the same manifold?
Thanks,Rob
Old 19th May 2016, 18:56
Thanks,Rob
Hi Rob, the 175's won't fit on the standard manifold without adaptor plates as the studs are 1/4" (6.35mm) further apart to allow for the bigger throttle opening. You also need to use appropriate needles for your engine (I don't know anything about needle sizes on these carbs btw, so no point asking me for more details).
My 1.75's came via ebay with the adaptors included and the correct needles for my Vitesse motor already fitted as the seller had been running them on a Vitesse himself.
The adaptors are pretty basic (I suppose I should've taken some pictures before fitting them). They're about half an inch thick (12.7mm) with countersunk holes that take flush set-screws to attach them to the manifold using the threaded holes left by removing the original carb mounting studs. The wider spaced studs are pre-attached to the adaptor facing away from the manifold and you just bolt up the carbs with new gaskets at all the joins.
The only other mod necessary was an extension to place the throttle cable over the lever that operates the linkage as that lever faces inboard on the 150's and outboard on the 175's, so there's a difference of about 4" (100mm) between their locations.
I've noticed a significant improvement in performance since fitting them, but I have to say I believe most of that is down to the old ones being worn out rather than any real gain from the bigger throttles. I had planned to eventually fit a Chris Witor flow balanced manifold, but I've just this second discovered that they no longer carry out that mod.
http://www.chriswitor.com/proddetail.php?prod=CW3290
Anyway, good luck getting your carbs sorted.
I'm sure if you took your manifold and carbs to a machine shop they could knock you up something suitable easily enough (assuming you can't do it yourself).
