Old 23rd April 2014, 17:28
Hammy Hammy is offline
Default Hammys Kobra build
After looking around I bought the best donor I could find. Its actually so good Im going to look mad (again) stripping it.
Do any threads on here cover Z3 stripping?
IM really excited about this one and will be building two kits at once as my MEV is still ongoing
EDIT! This no longer the donor as the dealers were shady to say the least. Linky removed
Old 23rd April 2014, 22:00
redratbike's Avatar
Maybe talk to casomolino
http://www.madabout-kitcars.com/foru...t=4261&page=14
Old 24th April 2014, 08:59
Pages 2&3 of my build thread have some pictures. I think the basic principle is
Select a panel to remove
Look all around the edges for bolts and screws and remove them
Carefully disconnect and label any wires
Lots of photos of every step to post up here as a strippers guide for the future
eBay the scrap
Old 24th April 2014, 18:02
Hammy one weekend will do it , but you will need a second pair of hands for the bonnet and the soft top , front and rear lights sell really well , also the bonnet , all the best Geoff .
Old 30th April 2014, 12:44
Default Lights
Thanks guys, looks very straightforward. Looking at bits and quite like these;
http://www.ebay.co.uk/itm/1505669913...%3AMEBIDX%3AIT
Old 30th April 2014, 15:06
and these too....
http://www.ebay.co.uk/itm/1710152049...%3AMEBIDX%3AIT
Also ordered 1 of these to check out the quality, will let you know what I think....
http://www.ebay.co.uk/itm/2311087136...84.m1439.l2649
And got these to spray or powdercoat satin black
http://www.ebay.co.uk/itm/1712955038...84.m1439.l2649
Old 30th April 2014, 17:16
If you don't like the domed side repeaters then I used Ford Transit Connect side repeaters. Available in orange or white.
Old 30th April 2014, 20:51
Any piccys, are they modern led????
Old 30th April 2014, 21:40
Not modern but on the side of my car if you look at the latest pics
Old 1st May 2014, 12:39
Default wing badges
These look very Shelby like...
http://www.ebay.co.uk/itm/2614128758...84.m1439.l2649
And these maybe a more modern alternative
http://www.ebay.co.uk/itm/2614433291...84.m1439.l2649
Old 1st May 2014, 21:26
seanick's Avatar
seanick seanick is offline
Now this time, do be careful with the glass won't you!!
Old 2nd May 2014, 07:57
Hello buddy, no glass this time mate! ��
Old 6th May 2014, 13:13
Brilliant to see the 2 Kobras at Stoneleigh, totally sold on it! Now to finish my MEV and find an alternative Z3 donor
Old 12th May 2014, 12:42
Default donor
Got my 2.8 donor with some very cool mods to the engine, suspension and q shift gearbox.
I cleaned and renovated the hood this weekend and the results are superb. It may sound odd but if you want to remove all signs of dirt and mildew then avoid off the shelf stuff and do what I did after following a thread on cardetailing.com
1- Scrub roof with detergent
2- Rinse thoroughly
3- Soak hood in white wine vinegar
4- liberally sprinkle baking soda/ bicarbonate of soda over hood.
5- spray with more vinegar and leave for 4 hours
6- using a soft cloth and a mild bleach/water mix (1-10) wash hood
7- rinse thoroughly (or as I did rinse and go to car wash)
8- Allow to dry and view the amazing results
9- If you want to (I did) wipe in some roof dye with a soft cloth
Sounds crazy and a bit Jamie Oliver but the thing with cleaning mould is that its a living thing and comes back if you just clean it off.
Photo above is pre cleaning and the mildew is visible.
PS. A great mod for the 2.8 is a 325 inlet manifold, it has larger ports and adds significant BHP especially when coupled to a good induction kit like the K&N I fitted this weekend
Hammy
Old 12th May 2014, 12:53
y cymro's Avatar
y cymro y cymro is offline
Presumably you then threw it into an oven at 190 degree for 2 hours before enjoying it with a glass of Chianti?
Old 12th May 2014, 13:15
How much, how easy to do and where from?
Old 12th May 2014, 13:21
You cant drink Chianti with a car like this! Must be Tequila and no it was 180 deg
Old 12th May 2014, 13:23
Easy to do apparently (mine was done already) and the K&N was ebay £65 the inlet manifold check with a beemer breakers
Old 12th May 2014, 16:40
y cymro's Avatar
The air filter is unlikely to add much unless you have an effective CAI.
There are manifolds for sale on eBay. Be careful that you're getting the correct manifold and not being conned with a 323 or 328 one. It's not a straight swap as some pipe work changes and a couple of extra brackets are required. I'll post a useful link later.
The increase in power comes with a decrease in low down torque.
A remap will liberate most benefit with the manifold. All the above together with an M3 exhaust manifold will give you 240bhp.
Old 12th May 2014, 16:50
Correct, I may have been a bit nonchalant there but having modified many engines I call that straightforward for the power increase. Naturally you need CAI but I thought that went without saying.
