Old 5th January 2010, 18:27
ash's Avatar
ash ash is offline
ash is on a distinguished road
Default pinto ring gear
anyone on hear no how many teeth on a 2ltr pinto ring gear , i need a new starter to cope with engine starting as a standard one wont turn fast enough
Old 6th January 2010, 08:12
eaa53's Avatar
eaa53 eaa53 is offline
You need the hi torque starter motor.
The standard Pinto was .9kw the banger, grass and track boys use the higher rated 1.4kw motor.
I am looking for one myself but the scrap yards are cleared by the racers.
eBay at about £120 is an option!
Old 6th January 2010, 17:24
ash's Avatar
ash ash is offline
cheers for that, check the bay out after ive been 2 scrappers
Old 7th January 2010, 13:52
eaa53's Avatar
If you are really up for it you could do what the banger boys do and run the starter (only) on 24 volt, that makes it wing a bit.
The motor will operate happily on 24 volt; they will fail sooner than if operated on 12 volts but we are talking about running over a race season without failure.
The second battery can be just a small race NiCad but you will need some fancy relay arrangement to charge it but is a fast fix.
eaa53
Old 7th January 2010, 18:46
ash's Avatar
ash ash is offline
ive seen a 1.4kw on the bay think ill go that route, i think its best bet in long run thanks for reply
