1st October 2013, 19:24
Originally Posted by The Shadow
so , is it getting a roof ? lots of people have talked about hardtops but I don't think anyones started one yet. Tribute got as far as propping one together and the original Sammio guys and Miglia have talked about it , will you be the first ?
If you look at the original donor you'll see there was a lot of parts missing including the roof.
This is only the first effort but it's going well and I think an original fold-down roof with side screens could be fitted the next one, so watch this space
That said has anybody got a roof or frame going spare??
4th October 2013, 10:24
The body it now cut to fit some where right and hopfully you can see my "vision" by keeping the baulkhead and windscreen in place.
Doors will be bonded in place.
4th October 2013, 11:08
Does anyone remember the Vincent Hurricane? Yours is prettier.
4th October 2013, 16:54
Doors now fixed and the body's fitting better.
The bonnet will need alot of "re-styling"
4th October 2013, 18:00
Are you planning to "graft" what is left of your Spitfire bonnet to the fibre glass one?
You are making great progress so far & I look forward to the rest of this build.
4th October 2013, 18:18
That's correct, if it all goes to plan I should end up with a nice curve forming between the fiberglass bonnet to the steel bonnet
5th October 2013, 18:47
5th October 2013, 23:00
Special Doors
Micky,
I do think the cut down doors give this car a little bit of extra eligance.
Excellent job.
HM
6th October 2013, 07:58
Originally Posted by micky1mo
... Bonnet now "re-formed" ...
You are making this look very easy.
Any chance you can talk us through the process a bit?
Do you have any photos of underside of the join?
This "joining metal to fibreglass" approach might help we when I start work on my bulkhead.
6th October 2013, 16:26
As requested, the joint.
7th October 2013, 17:40
Thanks for the photo.
So was it just a combination of bonding, riveting & fibre glassing?
The bonnet should certainly keep its shape better than a "just" fibreglass one.
Plus you will have "factory" shut lines where it closes too.
Keep up the great work, Paul.
8th October 2013, 07:55
Sorry, I was so busy looking at the join, I missed the other significant thing in that photo...
This is the first photo of a Navigator/Cordite with a working flip up bonnet in place that I have seen.
That's not to say, no one else has done it before, just that I've not seen a photo on here.
Obviously I'm now going to ask you how you got that to work too.
8th October 2013, 08:19
Strange question, as I thought they all had a flip bonnet, the same is fitted to the G-46
Why not call at my workshop next time your travaling along the M4 (10 min from J16) where all will be explained. I also make a great cup-of-tea
8th October 2013, 16:57
Thanks for the offer of tea, I'll bring the biscuits if I am ever passing.
Just to explain the comment about the bonnet...
Yes, all the Cordites / Navigators came with a flip up bonnet.
However, they could only be fitted after a large section from the front of the chassis was removed.
But in order to get the re-body inspection, the chassis must be unaltered.
So personally I'm still waiting to sort out the body before I can get a working bonnet.
I hope that makes sense, Paul.
9th October 2013, 06:17
TX tripper comes to mind with the doors cut away!!!!!!!!!!!!!!!!
9th October 2013, 09:34
Could you tell me what materials you have used to bond the fiberglass to the metal bonnet please ? I have tried to that in the past on a trike project and had very little success in getting it to bond affectivly.
I have been told epoxy glue by a local chap who used to make a vw beetle bodykit but don't know which one as there are loads of diferent types.
11th October 2013, 14:33
Anything ?
11th October 2013, 16:15
Anything ?
Hi I am not sure but i can see red spread?
11th October 2013, 16:29
red spread ? Do you mean the stuff they call Kitty hair ? looks like Ronald Macdonalds pubes in a tin of grease ! I thinks its called p38 or chopped strand mix professionelly.
I didn't have much luck with that sticking properly to metal but talking to a bodyman who certainly sounded like he knew his onions he said it has to be mega scratched up first and you use a specialist primer. does that sound right to you mick?
11th October 2013, 16:42
LOL well thats another way of putting it .
