1st September 2007, 08:36
High Power Turbo and Type R owners
Hi guys.
Just wanted to for warn you about the power these cars have in a tiny little car. Caught me totally by surprise. I discovered this week the hard way. For 700 miles, I got used to the car. The chassis coped with what ever the engine through at it. No loss of controls at full chat. But this week discovered I have been running without the turbo due to a boost leak. since I've had the car. Fixed the problem. Result. Spun the car 180 degrees. The torque at 3-4k just took the back end out and over took the front. The power was frightening is the only to describe it. Now I know all of this was down to my bad driving. But just wanted to warn the others what to expect.
I was not hurt. Car is damaged. Assessing this weekend. First glance, there is not much damage (wishbone, shock and bonnet). But the chavs pinched the bonnet while I was recovering the car. Stole the morette headlights and front spoiler. Basically broke the low half of the bonnet. So now bonnet is not repairable.
I have drove so very fast cars. But I learned a valuable lesson. This car is like nothing else you will have ever drove. Period. Respect it. I will in future.
Highly recommend these track days Marlin are doing to test the car.
1st September 2007, 09:08
Unlucky dude at least you where not hurt
I have allways planed to do some track time to learn what the car is capable of doing befor ranting it down a road
Hope you can fix it
Big fella
1st September 2007, 09:41
John, not a good story to read, but the fact you're posting and unhurt is pleasing.
Hard to believe you crashed and some scum stole things from you! Did anyone stop to help you?? The public at large are quite disturbing in this country at times - a motorbike and car collided right in front of me on Tuesday, and despite many people seeing it, not ONE other person stopped! I even got some really funny looks as I stuffed my car on the verge and went to check all were okay!
1st September 2007, 11:07
John,
Glad to hear you're OK....it's loads easier to fix cars than bones.
Shame about the s**ts who nicked your bits....I guess Marlin can supply you the bits you'll need to get her back together.
If you've got a knackered damper and wishbone I'd check the chassis geometry as well to be sure....it's easy to twist bits on small box section spaceframes and not notice.
What did you hit?...kerb? or verge?
ATB
Rich
1st September 2007, 11:16
Thanks for your support guys.
The car spun while in second gear on the entry slip to a dual carrage way. It goes up a hill as the main carrage way is on a flyover. My mistake was I floored it as I was going round the bend as the slip starts so did not get very far up the slip road. The car spun and hit the kerb.
I did this plenty of times while the turbo was not working and felt really confident in the car. Boy was that a big mistake.
Going to get the car up high today so will take some measurements of the chassis to supply Marlin when I order the bits. Did a quick diagonal measurement of the fuel tank top area of the chassis. And corner to corner, of the box section, there was a 8mm difference. But will strip today that area and take some more accurate measurements over the weekend. Will also take some measurements of the rear section.
Just wanted to warn people that the car will bit!
How the car felt.
This story reminds me:
http://darwinawards.com/darwin/darwin1995-04.html
1st September 2007, 12:16
Glade to hear your ok, and hopfully not too much damage to the car. Mark is fitting 205 tyres on his and dylans race cars as the back is sliding with 218bhp, so maybe worth a couple of wider tyres on the back to help keep it in line, in the future. If your not expecting it its always worse, hope you get the car up and running again soon.
1st September 2007, 13:58
Sh*t luck John.. Very sorry to hear!
Like the others have already said - the main thing is that you are ok!
For the benefit of others: I hope that I don't end up sounding like an old granny - but these cars really need to be respected - especially on public roads!
Quite honestly, I've spun my race car numerous times on the race track - even when it only had 160BHp!! Anything over 200BHP in a car that weights little over half ton really needs to be respected if not feared!
Go on a track day or two and find the car's limits (and your limits of course).. Spin it a few times in a controlled environment where you are not likely to damage yourself or the car and then you will know how far you can push it on the road..
Hope the chasis is ok John and that the repairs will only amount to spanner work..
Dylan
1st September 2007, 15:34
John, Just got in from work and read this....I am totally gutted for you but so pleased you are ok!
You are right about the fastest thing that poeple have driven, with their power to weight they are way up there with the supercars.
Hope you get it sorted soon
all the best
Craig
1st September 2007, 16:28
Stripped car today. Fuel tank out springs/wishbones off. Will take some measurements tomorrow. Raised car high enough for even me to slide under the car. Gave me a great deal of satisfaction to actually get a spanner and rachet in my hand again.
Fear is the word Dylan. Pins you back tightly to the seat and hang on to steering wheel for dear life.
Thanks for all your support guys.
Hopefully all will be ok with chassis.
1st September 2007, 16:58
How awful after only just getting it finished!
You might want to get your insurance guy out to inspect the damage before you dismantle too much?
I presume you have lots of photo's?
Peter
2nd September 2007, 21:03
Cheers guys.
I want to say a big thanks to Steve (SDMC001) and Ian (merlinman). We checked the damage. The lower chassis rail has moved But not a big job to repair so Ian tells me! Front area that front section hooks on to has moved. Again Ian says but a big job. Reweld soome of the joins to just to be on the safe side.
Car is now back on it's wheels and pointing straight! Parts I need are top and bottom wishbones for the rear (borrowed Ian's lower wishbone) to get her back on her wheels. Front and rear uprights. Front ball joint. And new bonnet and spoiler.
So hopefully not too much of a job to get her back on the road.
Steve took me for a ride in his 5EXI today. Lovely job Steve. A bit of a psychological thing for me but drove past the crash scene in another 5EXI. Steve offered my a drive. Thanks Steve. But again a psychological thing, only one Marlin I want to drive past the crash scene.
Hopefully see you soon at a meet and shake all your hands for your support.
3rd September 2007, 12:40
John,
It's interesting you metion the boost control, as I was going to ask about that.
I guess you fitted a dawes-esk device (ball and spring job), which if it has the same effect on your car, as it did on my friend's car, the boost coming in, is rather like a switch.
Does the rover normally run closed loop boost control if running a solenoid valve?
A VX220 turbo has very progressive boost, to reduce the chances of mid corner "chug chug, kabooom" style boost build.
Although you can modulate the throttle to an extent with your right foot, would it be worth getting an adjustable electronic boost controller? From what I recall the dawes devices can cause pretty hefty boost spikes, and a decent electronic controller should help reduce these, amongst other things and give you more control in general.
Good to read that fellow builders have mucked in and helped you.
3rd September 2007, 16:56
Just got back from holiday and read this, great to hear you are ok and couldn't believe someone stole bits from the crash site. Main thing is you are ok. Nick
3rd September 2007, 17:12
Hi guys. My ECU controlled one was knackered. So I bought an up rated one. Great little device for the money. But as you say a slap in the face with a wet fish once 2.5K revs appear!
Will get a proper boost controller eventually. I just learn to drive it better.
Your running gear is from a 800 turbo if it's from Marlin. They had 2 different power output's for the 800 depending on year. 1800 HP and 200HP. Mine was from a 200 HP coupe. If your's is 180HP version, you should have a lot more control.
I think as a whole, there is a great 5EXI spirit.
Hopefull sorting chassis out this week.
3rd September 2007, 22:16
Had a weekend away myself so only just read this. Gutted for you mate, glad you're ok.
Made me think: I've lost track a bit - is anyone actually running a type R car on the road yet? Any drivability feedback? I guess the VTEC point will have a bit of a "boost spike" type effect, but hopefully a little milder...
Richard
4th September 2007, 10:54
Rich,
The v-tec step with the I-vetc is pretty mild (at least it is in an EP3 Civic) as a product of the variable inlet cam. There is still a slight spike, but the engine being NA works in our favour. I reckon we can drive around v-tec and with the hondata we can certainly dictate exactly when it comes in – boost in my experience is far harder to adapt to.
That said, I know the moment I try and drive mine with any vigour on track, I’ll spin many times! I think as modern cars are so often FWD, and even when they are RWD they’re fairly heavily pacified, very few people can really drive properly. Certainly my skills are pretty poor - the last time I was on track I spun a FWD 360 deg at 90mph, (much to the amusement of my friends watching!) due to LOO, and not reading the track surface very well (damp patch mid-corner).
Whilst I’m not worried per se about driving my car when it’s done, I’m going to tread very very cautiously for quite some time! John’s story has certainly confirmed what I expected – very square footprint, mid engine, low inertia, gives the car an ability to spin quickly when it goes!
On a side note, I hope there will be quite a few 5EXIs at Llandow, as I would really like to see one going at a respectable pace on track – I went in Dylan’s road car at Brands Hatch a couple of years ago, but that is now quite a distant memory. I reckon the 22nd will be quite an amusing day – my car has a paultry 135bhp / ton, so I expect to be little more than a rolling roadblock, with overheating brakes and floppy suspension!
Cheers,
John.
4th September 2007, 11:36
Fingers crossed, I might even see you there in mine. We will see.
A lot of work to be done, but parts could be arriving sooner that I thought....
Boost will be turned down for me though. Unless Mark gives me the nod on the track. Learn from others.
4th September 2007, 12:04
The Vtec does kick a little, but nothing like a turbo, unless you change the cams, my mate fitted Toda Killer cams in his S2000, that kicked when you changed up through the gears, now its an animal but fine if you are on the Vtec but if you floor it in a straight line the back stil kicks when the cams come in. Cant wait to get my brakes plumbed in so I can take it down the road and give it a little blast.
4th September 2007, 12:27
S2000 is more agressive though, as it has static cam timing. The I-vtec can can adjust the inlet cam phase, which smoothes the torque curve through the revs.
http://www.twminduction.com/Throttle...s2000_dyno.jpg
Pretty aggressive mid-rev punch.
4th September 2007, 12:56
Arh that makes me a little happier knowing that it should be smoother, well hope so give me time to learn how to drive. Got to start learning quick only have the 2008 season before the new engine goes in.
