31st October 2017, 21:07
This is what we did to the Formosa ..it takes a lot of the flex out and creates inner wings too ...
12mm plywood bonded and glassed in place and then flo coated ..
1st November 2017, 08:25
scimjim It might be worth a go and save some time.
Are you heading my way over the weekend?
lancelot link That's a worth while idea.
The extra rigidity and weight should also stop the bonnet "lifting" at speed.
1st November 2017, 12:36
Nicely done!
2nd November 2017, 18:07
3rd November 2017, 09:59
Hi micky1mo,
Which bonding paste are you using please?
Thanks.
3rd November 2017, 16:26
THAT LOOKS LIKE PINK GRIP TO ME ...Its widely available in Screwfix type outlets ...I use a variety of different ones , again 'borrowed' from the building trade as its does the same job as the Automotive stuff but about a third of the price ...
4th November 2017, 09:47
Thank you vey much for your reply Gary. Formosa you have built for Alex looks fantastic btw. Good luck with building the long nose one.
4th November 2017, 13:01
Thx ..very pleased with the results ...keep posting updates on your build ...The Miglia's have the potential to be very pretty cars ..
4th November 2017, 16:41
deni There's lots of different bonding agent on the market and each person will support one or the other.
Personally I to use various bonding agent for various jobs but mainly these three.
The Bonding paste is really good stuff and make a strong ridged joint but needs to be mixed with eather catalyst or hardener so can be messy.
The "Stixall" is a very good silicon adhesive and remains flexible so is ideal for fixing down fuel tanks and windscreen but at around £6 per tube it's not cheap.
At just over £2 per tube "Pinkgrip" it a inexpensive filler/adhesive that is easy to use, takes a while to set, holds well but it's not flexible, also it's self life once opened is short.
4th November 2017, 19:12
I like the Stixall as well ...I think I pay about £4 something locally , but I have had an account with the same firm for over 20 years ...
even at £6 its still cheaper than Sikkoflex and Tiger seal and they come in smaller tubes .....
There are a couple of sikka products around the £6 mark too ..
6th November 2017, 19:21
Boot lid fits nicely.
I used the original Triumph Spitfire fuel cap and original Triumph Herald boot hinges
The standard Triumph Herald hinges fit the body profile perfectly allowing the boot to open smoothly.
The next big issue is the dash lay-out.
6th November 2017, 20:12
Nice!
7th November 2017, 20:14
micky1mo-Thank you very much for the info on adhesives, very helpful.
Gary- thank you too for additional info, much appreciated.
30th January 2018, 17:16
30th January 2018, 18:25
deni
I think Stixall is Polyurethane, which is quite different to silicone (although it looks similar)
31st January 2018, 16:39
Finished off the rear lighting.
Their all there STOP, TAIL, INDICATORS, FOG, REVERSE
3rd February 2018, 17:16
I am keeping the front light set-up fairly standard
I will replace the front and rear number plates with stick-on period "show only", plates after the MOT is passed .
8th February 2018, 19:04
A standard Ford Cortina radiator fitted nicely between the chassis rails and bolted to the chassis cross member.
The lower coolant hose route took a little effort to work-out but the top hose was a simple fit.
I will fit some upper supporting brackets later
After switching a few crossed wires every thing tested OK so I'll try and fire it up in the morning.
12th February 2018, 13:12
Mike - Looks like you could have this finished and painted just as Spring arrives.
12th February 2018, 19:04
With a little luck I should have it finished, painted and sold BEFORE spring arrives .
