Old 27th June 2015, 20:42
Default MGF Alloy Wheels
I notice a number of Sammios et al have MGF alloy wheels. What work is required to fit them: do people retain the 3/8ths studs (and if so, which nuts do you use to secure them?), or convert to M12 or 7/16ths studs?
Thanks for your advice.
Old 28th June 2015, 17:48
micky1mo's Avatar
micky1mo micky1mo is offline
You'll need a nut and a pair of washers for each stud to fit the MGF wheels.
You can get them from here http://www.speedshack.co.uk/
A full set of 16 will be around £60
The wheels will then bolt straight-on but sit close to the rear axle tie rod.
Only the small lugs on the rear hub centre will have to be ground off.
