16th April 2012, 06:02
Chris, nothing on the body is square and both sides are not a mirror image so it just needs to look right on your car, don't try to be too perfect! Although you will know all the little bits that are wrong, everyone else will not notice when it is on the road.
So what I did......
1. Check the bulkhead is square with the frame and on the chassis first! Then bond the body onto the frame inside so it is in the position you want and will not move.
2. Use the bulkhead as the datum and try to match both sides so the bonnet shut lines down each side are approximately in the right place. Don't try to be mm perfect.
3. The important thing is the angle of the shut line as this needs to match the bonnet, so I measured about 2" back from the edge and drew a parallel line
4. Draw another parallel line about 3" back from the edge and this will give you 1" as the amount you will cut out. I extended both lines to the top of the body just short of the mould line on the top.
5. I then carried the 2" line from the top of the body to the centre of the body at the top and stopped in the middle. The 3" line then got drawn to meet the 2" line in the middle so you have a wedge shape. This allows you to keep the bonnet line from the middle and basically bend the top part back to meet your new line when you have taken an inch out of the side.
6. I then cut out the band of 1" down the side and moved that section back, pinning it with some little brackets - these were just kitchen unit right angle brackets that were flattened. Remember to leave a 2-3mm gap so you can get some bonding paste in the gap.
7. Cut your wedge out of the top so you can adjust it to meet the new shut line, I used a bracket along the shut line where the two bits meet to keep it all straight.
8. Once you are happy with it all, then whack some bonding paste in and some matting underneath when you can reach. The side will be supported by the paste you put in to close the gap between the bonnet and the bulkhead so that will keep it all solid.
The only thing to bear in mind is that since I have modified the body, I am expecting to have to adjust the bonnet to fit, as I expect it now to be an inch short on the passenger side.
From talking to others and seeing a couple of finished cars, some body's fit better that others and to be honest, I have only noticed the difference from side to side as I and looking for it, no one else will notice it! Make it fit as best you can but don't try and get it perfect as it will start to have a knock on effect with other stuff!
Good luck.
16th April 2012, 07:56
Tony,
Brilliant explanation - thank you very much for taking the time. Agreed, nothing is true, sqaure or symetrical and that is why I have been scratching my head as regards the best datum to use.
The good news is that you may find that your bonnet is now correct. When I first noticed that the passenger side was 50mm further forward, I tried the bonnet in place (to judge whether one side or both needed to be modified).
On mine, the driver's side bonnet and body shell were almost perfect whereas the passenger side the bonnet was about 50mm further back than the front of the body shell!
Thanks again.
Chris
16th April 2012, 08:50
Originally Posted by cbjroms
Tony,
Thanks again.
Chris
I have my inspection this Wednesday, so this weekend is all about getting the bits cut off so I can fit the bonnet and tidy up the back. I look forward to my bonnet fitting then!!
I am going to run 15" wheels, and at the moment, the rear wheel arches are a little low and not quite the ideal shape, so I may adjust those. I will wait until it is all together before cutting, but they should be pretty easy by comparison.
17th April 2012, 16:00
Originally Posted by tlrtone
I have my inspection this Wednesday.............
GETTING NERVOUS YET ?
See you about 9.30....
17th April 2012, 18:16
Good luck matey, you'll be fine!
17th April 2012, 18:22
Yes, good luck for tomorrow.
17th April 2012, 20:02
yep, I will be up early and getting it ready!
I put the 13" wheels back on but it is a tad low now so I might put the 15"s on for tomorrow.
I'm looking forward to the unnecessary "bits" falling off tomorrow afternoon
17th April 2012, 20:29
best of luck Tony
17th April 2012, 21:12
All the best from us Tony,
We are hoping to follow you very soon, don't forget pictures!
Paul D.
18th April 2012, 09:56
This is a before inspection shot...
An this is during the inspection....
BIG THANKS TO GARY for arranging the inspection
I now have a reborn classic - a 1964 SAMMIO SPYDER
time for some 'bits' to fall off.
18th April 2012, 10:31
whoo hoo! congrats matey.
18th April 2012, 12:17
So it all went well? It must be such a relief to get it signed off. I would say its the most difficult part of the build!
18th April 2012, 12:39
Yep, about a 10 minute inspection. So I just wait for the altered log book to arrive in a few weeks time!
ooops, look what "fell off" on the drive....
I'm just having a go at fitting the bonnet in between rain showers...
18th April 2012, 12:42
Are you going for the battered look as well...
18th April 2012, 12:43
not intentionally Gary, although it is growing on me.....
18th April 2012, 12:50
Excellent news, a well spent ten minutes by the sound of it. Congratulations!
Can't wait for our turn soon.
18th April 2012, 12:57
Food for thought!
Do I talk nicely to Gary and try and coincide an inspection with the proposed meet-up....or do I attempt to be the first to go through the inspection at Maidstone....dilema?.....the other problem is I washed the purchase receipt...do you need it for the inspection? (I know..you are meant to launder the money not the recepits)
18th April 2012, 13:15
Originally Posted by Nick59
Food for thought!
Nick, it might be worth having a call to the local Maidstone office first. If they sound receptive to the idea and don't want to make a mountain out of it, it may be more convenient.
That said, a day out to Poole is a small price to pay for a simple, hassle-free inspection, attended by Gary himself to ensure there are no problems.
I would suggest doing the inspection as soon as you can, to get it out of the way and so you can then relax and continue the build! It is not difficult, but a great feeling when it is done!
18th April 2012, 15:17
Nice one Tony!
Having the ends of the rear outriggers corrode through and drop off the very afternoon after the inspection is an amazing coincidence, it's just lucky it didn't happen a few hours earlier or you'd have had to weld new ones on...
Oh, btw, did you actually need to show them the receipt for your Sammio body? Only mine got turned into a mouse nest when I left it in a box of bits in the garage.
18th April 2012, 15:34
Nice one Tony!
No reciept was required. In fact, they have just called me and asked me for the mileage as they forgot to take it They didn't ask for any paperwork, apart from the logbook and the completed form from gary's website, which were given to them when we booked the inspection.
A simple, painless operation....
