4th June 2005, 16:22
Ignition switch turbo.
Hi everyone.
Just trying to make a start on the wiring. But it seems the colour codes on Rave between different Rover Models are different. I have a 220 Turbo coupe donor. For example the 420 diagram has Black/Green, I have Black/Yellow
There are two connectors on the switch. One 5 Pin and one 4 pin.
5 Pin:
Top of connector
More Black/ White, Blue/White, Purple
White, More White/Black
4 Pin :
Top of connector
White/Red, Black/Yellow
Yellow, Purple
I've worked out that the purple is illumination for the switch.
Anybody know where I can get these pin outs? I've checked on Rave and the 800 haynes manual.
4th June 2005, 16:59
hi john
I had the same problem. If you use the connector with the thicker wires (higher current) it should be all you need. use a multimeter and it is very simple. Indentify the pos in from the battery then connect the multimeter to it and turn the ignition switch to each postion and identify which wire works on postion 1,2 and crank/start.
If you cannot idenify the pos from the battery then switch to postion one and check each of the thicks wire in turn until you have a pair with a circuit. Then switch to postion two. and using the two original wires in turn check the rest of the wires when you have a circuit from one of the original wire that is your pos feed from the battery.
All the other wires can be isolated, they are for other switched pos feed to windows, rear screen, radio etc. Then it just a matter of matching the correct wire to the marlin loom. Green, purple, white and brown i think.
hope this helps
tony
4th June 2005, 17:41
Hi Tony.
I've got 7 Thick Wires. I have no battery connected at the moment. I'll go and have a go with the multimeter now and let you know.
Cheers Tony.
4th June 2005, 18:41
Hi Tony.
I've been busy with the multimeter. Here are the results:
Postion 1 (Off) - No readings from any pins.
Position 2 - More White/Black shorts to White/Red.
Postion 3 (Ignition) - More White/Black shorts to both White/Red and White/Blue
Postion 4 (Crank/Start) - More Black/White shorts to both White and Black/Yellow.
Does that make sense?
4th June 2005, 19:23
hi john
that almost makes sense
white / black is the perm pos feed from battery
postion 1 no circuit (every thing switched off) black / white would be live if connected to battery
postion 2 (auxilary) white / red out to any auxilary circuit you want to put in ie. radio
postion 3 (run) white / blue provides the switched positive for the marlin fusebox and the switched pos to the engine management. The white / red remains live to feed the auxilary circuit
postion 3 (crank) use white as output (that matches the marlin loom and use one of the remaining wires to connect to the battery perm pos feed. I think this right but i will check my crank circuit diagrams because i am preety sure the white connects to the engine management for crank
but the other two seem strange black being the major colour would suggest earth not live.
all the best
tony
4th June 2005, 23:38
Cheers Tony.
I see what you mean with the Black/White wire. This wire was cut. the ends looked like they had been solder at some point but not connected to each other. I thought they may have been for the key on dash immobiliser that was fitted?? I connected them up with a bit of wire to do the testing. There is also a black wire on it's own with a spade connector. Any idea what this is?
If you could check with yours that would be great.
5th June 2005, 11:17
morning john (well just)
I will try to have a look a mine later. but i have been tasked with domestic duties first by the one that must be obeyed. Have you checked all the wires in both connectors to the white wire while ignition held in start postion.
the other thing is you can take the black plastic switch of the back of the ignition switch and look at the numbers on the back against each connection this should match up with numbers on the wiring diagram for the ignition switch
black wire must be an earth. could be horn, or your ingnition barrel light.
I had one thought is your donor fitted with the alarm/imobliser unit. mine is not and i am not quite sure what difference that make to the ignition switch. my donor was a 220 gti for most things except the engine which is from a 820 vittess
get back to you later
tony
5th June 2005, 12:00
Hi Tony.
Yes I check all the wires for the white and it only shorts to the Black white while in start position.
Ah that black plastic switch. It's only held on by two screws but trying to get at that top one is a bit of a challenge.
It was fitted with i think just an alarm but an after market immobiliser that you put a key fob into on the dash. I'll have another go at getting that top screw out on the ignition switch.
Cheers Tony.
5th June 2005, 13:10
Hi Tony.
I've managed to get to the switch (drilled out the switch screw things). Here is the bits on the back.
Upper level:
Top of switch IG1 : Black/Yellow
Middle of switch Bat B : More White/Black
IG2-B : Blue/White
Bottom of switch : BAT A : White
middle level : Red/White no label
Lower Level and left of the switch :
Top : yellow no label
Middle : More Black/White
Hope that makes sense!!
Cheers John
5th June 2005, 17:03
hi john did you get my personal message?
it would seem just the same as mine ok here we go
yellow and black/yellow isolated and not used.
white/red is postion 1 and 2 switched pos out. This connects to the marlin loom green wire that feeds the marlin fusebox.
blue/white is postion 2 switched pos out this connects to the marlin loom green wire that goes to the rear of the car and is the switched positive feed for the mems engine management relay.
white and white/black are joined together and connected to marlin loom brown. this is the perm pos feed to the ignition switch. the reason you have two wires joined is the switch is in two parts inside.
this one might need checking but it looks the same. Are you sure it is black/white and not black/light-grey like mine.
black/white or black/light-grey connects to the marlin loom white wire and is the pos feed to the start relay. easy to check if you have a circuit between the joined white and white/black and the black/white or black/light-grey when you switch to crank postion and the circuit is deed when crank is relesed back to postion 2 all is correct
hope this has sorted it if not give me a call
all the best
tony
5th June 2005, 17:53
Hi Tony.
No did not get your PM.
The Black/White definitely looks like Black/White and not Black/light Grey.
The black/White is at the end of the big 5 pin plug. The blue/white is next to it and the white is below it. Is this in the same position as your black/Grey?
