23rd October 2012, 21:35
Up and running...about time to!
After buying my kit way back in August I have managed to get the MX5 into the garage this week and start my build.
This is my progress on day one.
23rd October 2012, 21:38
It won't take long Dave. I see you have a wood burning stove in the garage for those long cold winter evenings! Keep up the good work
5th November 2012, 20:06
Making progress
No turning back now. Sills all welded up, roof bonded to screen surround and rear section tiger sealed and screwed on. Just waiting for it all to cure now. [/IMG][/IMG]0118059A02720_zps57065a76.jpg[/IMG][/IMG]
5th November 2012, 20:08
5th November 2012, 20:24
Took me ages to find the right image code. Are you using photobucket?
5th November 2012, 20:36
[QUOTE=Dave Lowes;37174]No turning back now. Sills all welded up, roof bonded to screen surround and rear section tiger sealed and screwed on. Just waiting for it all to cure now.
[IMG]0118059A02720_zps57065a76.jpg[/IMG]
Managed to recover 1pic
5th November 2012, 21:12
You've gone and done it now! Great progress:-)
5th November 2012, 21:38
Yes photobucket but i downloaded the app on my phone and i dont think it has worked as well.
6th November 2012, 07:24
Good work Dave. Photobucket can be a pain, but the more you use it the easier it gets.
Don't forget to cut, bond and rivet some steel plates into the doorshut/windscreen head area.
I must get back onto doing the BUILD MANUAL!
4th January 2013, 19:22
After a brief holiday i am right back into it. Still in the process of filling and sanding, filling and sanding, filling and sanding. Cant wait to start something other than filling and sanding but its gotta be done
[/IMG]
4th January 2013, 20:00
I can't see the join Dave!! Great work The hard bit's done, now all the fun bits to do. Keep posting the pictures.
4th January 2013, 20:53
Hey dusty, looks very good. Did you cut back the body to the old bonnet line, around the screen?
4th January 2013, 20:56
Hi Seanick, yeah i cut it to that line. Thought i would give it a go. It looks allright. Saves a job messing around with the wipers.
18th January 2013, 16:11
What do i do with the headlights!!!!!!
I have kept the headlight units of the MX5. Is it best to use these. If so what chrome surrounds are best. Just preparing stuff ready for when i finish my sanding
18th January 2013, 16:27
Hi Dave
Here's some links for what you need:
Headlights: http://www.ebay.co.uk/itm/Classic-Mini-Headlight-Lamp-Halogen-Conversion-Kit-7-Sealed-Beam-Wipac-Lucas-/360531156285?pt=UK_CarsParts_Vehicles_CarParts_SM& fits=Model%3AMini|Plat_Gen%3AMK+I&hash=item53f154d d3d
Headlight buckets: http://www.ebay.co.uk/itm/PAIR-7-Pla...item5ad832695d
Chrome rims: http://www.ebay.co.uk/itm/MGB-Chrome...item2ec5297c17
You will need to trim the back of the headlight bowls before fitting. The headlight rims are the clip on type not the one's with the screw fixing at the base, you would have problems getting the screw in once fitted.
18th January 2013, 20:24
Great. Thanks. I will get looking.
2nd February 2013, 19:49
My car now resembles a leopard, been busy filling all the gel coat voids. Do i need to fill every tiny pin hole and mark or will high build primer fill them? [/IMG]
2nd February 2013, 19:53
Never know which image code to use in the photobucket app. Will try this one. [IMG] [/IMG]
2nd February 2013, 19:54
Woo hoo. It worked
2nd February 2013, 20:11
I think the primer will help change the leopards spots, especially the small ones
Great to see the progress
