Old 10th December 2021, 22:29
Carib Classics Carib Classics is offline
Carib Classics is on a distinguished road
So after a long absence, when other projects were completed, my tools being stolen again, then there was Covid 19 lock down, I am back with my build.
This time I have replaced my Spitfire Chassis with a Vitesse Chassis which had been dry stored for thirty years. In great condition as my picture will show.
I had to exchange all my previously renovated parts in order to get this great chassis so the strip down, clean and replace worn out areas has begun.
Old 11th December 2021, 08:03
Welcome back, Carib - it's only been six years!
The longer chassis is a good move, it will really improve the proportions of the finished car. Can't wait to see some more progress
Old 11th December 2021, 09:39
deni deni is offline
Hi Carib,
Great to read that you’re resuming your build. It would be great to have another Miglia thread on the forum. I agree with MrT, the longer chassis will improve the look of the car.
Looking forward to following the progress of your build.
Cheers, D.
Old 26th February 2022, 21:20
So what do I have? Here goes, pics as I have them. Will try and put them in some sort of order
Old 26th February 2022, 21:32
Been trying to keep the build moving while I have some time. Its nearly Easter and the covers need to come off my other motor for the MOTs. So some more pics
Old 26th February 2022, 21:48
Default Getting It Built
Easter is soon and other cars will demand time so big push next few weeks
Old 9th July 2022, 00:26
Where is the year going. Didn't seem that long that I re started my build but its been 3 very quick moths.
So an update:
New thoughts on the engine and have obtained a MX5 Donor. Yes change in direction but should have as much power going to the wheels.
Stripped most of the Donor, including some of the trans tunnel.
All wiring loom with ECU, and of course the gearbox.
Hope the rear end can keep up or there may be another rethink.
Old 9th July 2022, 01:12
Default The Pictures Continued
My colours of Choice starts to GLOW
Old 9th July 2022, 01:25
Default Lot to show
Really enjoying this stage. Engine is in good condition generally, no smoke when tested prior to its removal.
General overhaul; New Cam belt, Water pump, Cam front seals, rust area cleaned sealed and repainted. Cam covers all replaced, used ones, cleaned and repainted.
Old 11th March 2023, 10:15
Default Engine works
So Chassis bare metal and painted, suspension and running gear cleaned and uprated.
So the build which should have taken two/three years continues.
Old 13th March 2023, 12:07
Have tried to upload pics of current position with build but having no success. Could be my location as I am overseas on holiday.
Back next week so will upload.
Old 13th March 2023, 12:58
Just spent some time looking and reading Deni's build and it seems so different to mine.
My subframe has very different structure, I assume Deni built his?
A couple of things which is now holding up my build. Due to my lack of welding experience I have been totally dependant on Kevin my classic car Guru. He has been very ill since Covid and is just getting back on his feet. Also I am using a MX5 engine and gearbox. I am using this waiting period to dry fit and position the engine combination onto my Vitesse chassis. I think I am almost there , will post the pictures soon as I work out how , or when I am home after my holiday.
My kit has been collected from Dan at OldNo7, so floor panel have been dropped onto the chassis just before I left for my break and I look forward to some input from you guys, to avoid the Noddy driving position, I feel that is so critical with this kit, along with the stance of the car generally.
Once the engine and gearbox are fitted I think my progress will be quicker.
Old 13th March 2023, 13:02
Miglia Red Body with Bonnet.jpgHELP !!!!
Can anyone help with my pictures posting? Also some picture format uploads on some of the other threads I can't open? I have tried both my PC and Apple laptops. Do I need to switch on an extension? HELP !!!!!
File Type: jpg Miglia Red Floor Pans and Windsceen.jpg (39.8 KB, 16 views)
Old 14th March 2023, 15:21
Default Engine Rebuild
So my pictures are posted out of order, but wanted to share these and invite feedback from the build teams.
Old 14th March 2023, 17:47
Always look great right out of the mould !
MX5 engine is a good choice these days, cheap to source and bullet proof !
Should go well in the light Triumph chassis.
Have to pop round and take a look some time !
Old 15th March 2023, 12:01
Default welcome visit
It would be great to see past builders
File Type: jpg Gearbox with Rough fit Donnor Tunnel copy 1 .jpg (97.9 KB, 12 views)
Old 15th March 2023, 13:00
Default chassis pics
Hi all, got my thread action back. Still on holiday so brain so relaxed. I will try and update where I am to date and show as much as possible so others can see and guild.
As this is my first rebody build I am always looking for detailed advice.
Most of my experience has been with rebuilding classiscs.
Old 20th March 2023, 22:50
Hi Carib,
Just saw your post, it is nice to see another Miglia build postings. I really like your choice of engine/gearbox - it will suit Miglia for sure!
You're right, I've modified my frame as much as I could. Like yours, the frame I received was really basic and did not have the pedals/master cylinders plate, prop shaft tunnel, etc. I did not know how to weld, so I bought a basic gasless MIG welder and gave it a go. My welding skills are constantly improving, and my welds are not the prettiest, but they pass my hammering test and are strong enough.
The idea was to use fibreglass version of the original bulkhead that was to be supplied with kit, but apparently there were problems with fitting it. At the certain point they stopped making and supplying the bulkhead with the kit, but never modified and improved the frame to make up for the absence of it.
At the moment I'm working on the rear of the frame. I have decided to make a compartment behind the seats and install fuel tank in it, instead having it all the way at the rear. I'll post some photos when it's all done.
Looking forward to following your build and good luck with it.
Cheers, Deni.
P.S. I have same problems with the photos upload, something changed a while ago. I emailed the admin on a few occasions....
Old 21st March 2023, 20:56
I can't comment on hosting your pictures directly on this site as I've never used it.
I use Flickr to host my photo's.
Not sure, but I think you can still get a free Flickr account up to a 1000 photo's.
Once the photo is uploaded to Flickr you hit the 'Share' button and then paste the 'BBCode' into your draft post here. When you preview your post, the pictures appear.
Works everytime!
Old 21st March 2023, 23:54
Thanks Peterux, I might try using Flickr.
Cheers, Deni.
