HI - a short video showing which hoses I plan to connect to where. Unfortunately I have one hose which I don't know where to put. Any advice welcome, useful advice is very welcome :-)
The join needs to be a T, join the two pipes and the hole on the back of the inlet. 22mm internal diameter and B&Q has no suitable hose. Hence the Grrr.
If the loose pipe is a does draw vacuum then what, if anything does it need connecting to?
It looks to me like on the old manifold it was connected after the throttle body. That means the suck should be at the unconnected end and will suck out of the black plastic thing it is currently connected to.
Thanks guys. The main issue I have is a big party tomorrow, hang over Sunday, no hose available in Southampton, work on Monday and an ankle op followed by 3 months on crutches on Tuesday.
Any fishpond/aquatic places in your area? I seem to remember that I have used a similar t piece in fishpond plumbing.
The other option is blank them all. They don't do anything important unless there is a brake servo hose.
