21st October 2017, 16:00
Playing with the 3D printer
The badge is looking okay. just not certain if I will actually paint it and stick it on the car yet.
20171021_165617 by WCA!, on Flickr
22nd October 2017, 11:18
Are you accepting orders?
22nd October 2017, 18:17
Sure - you want one?
PM me you address and you get a free sample
22nd October 2017, 18:41
Thanks- yhm.
22nd October 2017, 21:05
I will photo mine on the car in morning and you can say if you want yours bigger or smaller.
23rd October 2017, 09:31
So here is the badge fresh from the printer and then quickly blasted with some wheel silver paint.
20171023_101306 by WCA!, on Flickr
You can see a few strings which are easy to remove, and I should he done that before painting, but the lettering is more of an issue. I think this is because I shrank the design from 5 inches to 4 inches.
When you look at the main body of the badges there are bands around the edges and then a sort of rough infill. I have checked back on the design I downloaded and it is part of the design.
I think I will reprint this in 5 inch sizing and then spend a little time cleaning it up properly. I might even try a little body filler and then paint to make things smoother and brighter.
I will print a couple and send one to Ian for him to play with too See if he can make it look good.
23rd October 2017, 12:53
Outstanding!
23rd October 2017, 14:05
Clever, fancy having a bash at Zagota "Z" for front wings? If so, pm me a price. I will spray it myself. Are they durable? A gear knob roundle would be nice too, maybe could be set in acrylic.
23rd October 2017, 18:20
They are printed in PETG which is a fairly weather proof and food safe if that's relevant.
You could use my print outs to form moulds in sand if you want to cast stuff.
I don't have a computer capable of producing the STL files needed but anyone with access to a basic CAD package should be able to do them relatively easily.
I just down load other peoples designs from Thingiverse.com so I don't think there is a Zagota Z there. I was looking for Superleggera but couldn't find that either.
If you do want stuff printing then send me the STL files and we can work something out I am sure.
23rd October 2017, 18:36
Thanks both, I will investigate both options. I probably will not need anything until late spring / early summer next year.
23rd October 2017, 18:42
Originally Posted by Lucky@LeMans
Worth mentioning that a small ish batch will make it more viable rather than one offs.
I think I did 10 sets for JagTVR which was just under £100 inc P&P so £10/ set.
23rd October 2017, 19:51
The Zagato "Z" is easily made from a small flat of aluminum using a saw and file.
23rd October 2017, 20:22
The aluminium option will look a LOT better for the simpler shapes.
24th October 2017, 09:48
Good ideas, thanks gents. I could even use the Z of the Z3 as a start point for a template, so I will have a good think about that. I don't want, or need to have the Zagato Milano text imprinted.
24th October 2017, 10:05
And excellent they were as well, you just need to polish them so a buff is very handy.
24th October 2017, 15:47
Looks good and your idea sounds good. TBH all of the period grille badges I've seen do not have lettering so I would probably smooth that area.
24th October 2017, 18:06
I will stick it in the post for you tomorrow.
There are a couple of the smaller ones but the glass plate I printed them on shifted so they are not great. I was thinking you might want to try to form a mould from them.
Please post photos of what ever you do in the end.
BTW It is great for printing kids bangles. Lots of happiness with very little filiment used
20171019_195124 by WCA!, on Flickr
Frame corner clamps
20171014_151231 by WCA!, on Flickr
28th November 2017, 17:34
Awesome work! When oh when will an affordable chrome plating solution be available for 3D printing I wonder? By the way there are quite a few solutions available free for designing the files needed for 3D printing. Some are pretty easy - my 10 year old is learning them at school.
29th November 2017, 07:10
How about using the "Z" from the boot script of the Z3?
Cheap, plenty about and will give the car a subtle nod to the base car.
