Old 9th March 2008, 14:43
paulsul paulsul is offline
Kit Car Dreamer
paulsul is on a distinguished road
Default hood fitting
Hi guys, have bee off the project for some time but am coming close to sva time.
Does anyone have fixing instructions or advice on fitting the hood???
Also, the mirrors i bought from Marlin were too tight. When i tried to loosen one, the alloy base snapped!!!!!
Has any one got a spare n/s mirror for sale or a pair of better quality ones that would pass sva??
cheers
Old 9th March 2008, 15:41
limpabit's Avatar
limpabit limpabit is offline
Hi Paul.
Yes mirrors was tight on mine. I drilled out the centre and used a nut and locking bolt. A bit late for you now though. Mirrors are not spare yet.
Can't comment on hood fitting because Marlin fitted mine.
But there is a thread here that might help.
http://www.madabout-kitcars.com/foru...highlight=hood
Old 9th March 2008, 16:00
alackofspeed's Avatar
I've just fitted my hood. In jist I laid the hood in position, marked the outline, made sure it was symetrical each side, then drilled holes ~15mm above the outline marks, at 100mm intervals.
I bought fasteners from Woolies.
Hood stays on fine at speed, but as it helps contain the noise, I have to wear ears plugs with it!
Cheers,
John.
Old 10th March 2008, 12:49
Kit Car Dreamer
Default hood & mirrors
Thanks for the help guys. Photos will be usefull.
Any ideas where I can get new mirrors (sva compliant)
All the ones I have seen don't seem to comply other than the Caterham ones which will not look too good.
Old 10th March 2008, 12:54
limpabit's Avatar
If it's any help, the Marlin ones are motorbike mirrors.
Other than that, find out from Terry if the can send you some. You never know your luck.
Possibly in about 3 weeks, I could have mine spare. But not sure of your time lines.
Old 10th March 2008, 19:57
craig's Avatar
craig craig is offline
The mirrors are a honda design like these ones about 9th down cbr 600/1000
http://www.4-motorcycles.co.uk/acata...a_Mirrors.html
Old 11th March 2008, 12:24
Kit Car Dreamer
Thanks guys
You are great with the help
Old 11th March 2008, 13:36
MadDogMoggy's Avatar
MadDogMoggy MadDogMoggy is offline
MadDogMoggy is on a distinguished road
Has anyone tried fitting mirrors to the windscreen pillars like the Javan instead of to the body sides? Just wondered!
Old 11th March 2008, 14:33
Quite an appropriate question for this thread, as mirrors on the a-pillar don't work with a hood.
