Old 18th September 2007, 17:37
craig's Avatar
craig craig is offline
Default Brake bias!
I know brake bias valves are a no no for sva but are balance bars classed as the same?
Craig
Old 18th September 2007, 17:51
Ric H Ric H is offline
As I understand it, both are allowed for sva, as long as they are not readily adjustable. E.g drilling and split-pinning the adjuster, or mounting the adjuster behind a cover of some sort (needing tools to remove it strictly speaking I would think). That's my interpretation - not that I've tested it as I currently have neither!
Richard
Old 18th September 2007, 18:31
SDMC001's Avatar
SDMC001 SDMC001 is offline
Craig
I cannot find the detail, but I belive that if fitted, it must still allow the permitted required brake function to meet the SVA when adjusted fully both ways..
I must say after doing some 450 miles now, I do feel some reduction the front brake effeciency would be of benifit.
Steve
Old 18th September 2007, 18:51
alackofspeed's Avatar
Or improvement of the rear brake efficiency?
It seems sensible to me, to make the bulk adjustment by getting the natural front / rear balance near to target, then fine tune with adjusters.
Any of the standard setups (280 f / 260 r, or 260 f / 240 r) being as they designed for a FWD car, I can't see are a good base. My slightly dubious car-park-poll of production mid-engined cars has found most have near identically sized disc, but with a larger pad area on the front, and larger calipers on the front.
As for SVA approval, both Steve and Rich's views seem fairly logical, but from what I recall in an earlier thread, nobody knew the answer (assuming it is concrete, and not open to regional interpretation).
