Old 30th June 2014, 13:41
Jeffr4 Jeffr4 is offline
Jeffr4 is on a distinguished road
Andreas,
Det kan vara, och är inte ett problem.....
Old 30th June 2014, 23:20
slangenracing slangenracing is offline
slangenracing is on a distinguished road
Yes, absolutely Garyh that is the plan! Has to convince my fiancee to stitch something up!
So here comes the pictures of the assembled car! Colour got a bit dull in the camera, its more like the pictures when fresh painted...
A bit more scoop and wheelarches!
Best regards from Andreas
Old 1st July 2014, 06:36
Very very nice!
The light does not do the paint justice!
Beautiful shape.
Old 1st July 2014, 07:13
Axel Axel is offline
Axel is on a distinguished road
Cannot believe that was a silly Mazda! Well done Andreas, I am waiting for pics in the sun ;-)
Old 1st July 2014, 08:03
Looks brilliant, the badge is very subtle...
Old 1st July 2014, 12:47
y cymro's Avatar
y cymro y cymro is offline
That looks very nice Andreas.
What about a top tinted sun strip to visually lower the windscreen and roof?
(copyright acknowledged)
Old 1st July 2014, 18:41
Thank you guys! Yes i am very happy with how it ended up. Still has a lot of thing to do on the car. I am working on the exhaust right now. I will be posting about it a little later
Best regards from Andreas!
Old 1st July 2014, 18:43
Yes i Think you are right about that. It has crossed my mind! I maybe will put striping over it too... Has to think about it all and let it sink in for a while!
That miata look horrible fast!
Best regards Andreas!
Old 1st July 2014, 19:46
Andreas - Your car looks great.
The thing I find interesting is that the BRG paint does scream "look at me" in the way a bright yellow (or similar) would.
And yet the car as a whole really catches your eye and makes you want to look at it.
Top job, Paul.
Old 1st July 2014, 20:33
Jamma Jamma is offline
Jamma is on a distinguished road
Absolutely amazing... Interior looks fabulous too! Love the quilted material and the seats are very much to my taste.
Can I ask your specs on the wheels? Offset etc
Old 1st July 2014, 21:16
Thanks!
The Wheels in rear are 15x9 zero offset and a 38mm spacer. Fronts are 15x8 zero offset no spacer.
The Wheels are Rota Wheels, model RKR
Old 1st July 2014, 21:44
So now the persuit for power begins...
I have been looking for a header that would suit my Engine. I have found zero. Most are 4-2-1 headers, and that is not the way. I am very specific about what i want, because a lot of Power is hidden here. ALOT. So the natural way as usual is to do it your self. This header i made is calculated upon my Engine spec. Cams, cylinder head, rpm range, usage etc. So this is what i ended up with. Primary lengths and diameters are calculated, and also the collector which has a venturi to help midrange a tiny bit (high rpm range is favorised).
Startpoint for a collector, the "nose" helps the pulses to retain energy a bit.
First section of collector is finished
All the primarys are MIG spotwelded on the car, spots are then grinded down, made ready for TIG welding
Here is the finished header. All welding is done, and also the collector is finished.
Hmm... I wonder what comes out here...
Put on the car, it is not much space left... Pardon the messy engine, it will be pulled out as there will be some work on that one too
Very tight here...
So now for the rest of the exhaust... '
Old 2nd July 2014, 06:36
why do change from Mig to Tig?
Old 2nd July 2014, 07:30
The MIG is just perfect to use when tubes is on the the car, a lot simpler to just "aim and shoot" when holding tube bends with one hand and the welder with the other. I use a auto welding helmet.
The TIG welder on the other hand has several advantages over the mig (especially whith this thin materal). The main reason is the strength of the weld. When welding with the TIG it is a lot more conrolled melt than with the mig, ending up with a more even weld that has burned through everywhere. The MIG weld tend to build up on the material. The other big advantage here is when there is small gaps between the bends, it always gets weld threads in the bends with the MIG. Theese can come loose an get caught in cat-converter , disrupts flow etc. That does not happpen with the TIG welding. And offcorse, the TIG welds looks a hundred times better than the MIG.
Old 2nd July 2014, 17:16
Hammy Hammy is offline
Originally Posted by slangenracing View Post
And here is the Pictures of my finished interior! It is still dirty an so but anyways...
That looks awesome1 where did you get that material/vinyl?
Old 2nd July 2014, 21:07
Ebay!
http://www.ebay.co.uk/itm/Diamond-Qu...item4d1fa0d78e
Regards Andreas!
Old 2nd July 2014, 21:10
Made the exhaust today, 3" it is... But the silencer was way to loud , have to change that one. Will buy another tomorrow...
Old 2nd July 2014, 21:26
That exhaust you made is a work of art, and I am jealous!!
Old 3rd July 2014, 08:42
fatbloke fatbloke is offline
Andreas, are those light covers the ones that Chris makes and how did you get the black surround? BTW, the whole thing looks fantastic.
Old 3rd July 2014, 10:59
Thanks!
Yes theese are those that Chris makes. I masked them on the backside and sprayed a couple of layers black on the backside.
