13th October 2009, 08:33
Originally Posted by limpabit
Need to sort out clutch (not engaging at the minute after bleeding etc). Think it's the adjustment on the pedal.
John, What clutch line are you using? Is it flexi?
13th October 2009, 08:50
Hi Craig.
It's the same copper pipe I used with the other engine which worked fine. Needed to adjust for the Rover engine as well with the same problem so keeping fingers crossed. Using a different clutch bracket for the slave so hoping it's just a minor adjustment at the pedal.
I'm also using a 6 paddle race clutch and plate now as well.
6th November 2009, 21:12
John, it's been a while - any closer to being road-worthy?
7th November 2009, 04:21
Yeah it has been a little while. Having some trouble with the clutch still. Found mgf slave bracket not up to the job coping with the helix cover plate. Under pressure, the slave would just bend the bracket! So renforced that.
Got some new pipe made up to replace the copper stuff I had. Flex stuff this time though. So will fit that today. Then adjust the pedal end. See what happens.
See if I can get the clutch to disengage. If not, I will need to rip the box off and see if I can see what's going on.
7th November 2009, 15:17
Bad news. See through the starter hole today. Slave is doing it's do now.
But still no release from clutch plate. Stuck solid against the flywheel. Even after loosening the cover plate bolt. So started the gearbox removal process. Hubs, driveshafts etc.
Start on gearbox removal tomorrow.
7th November 2009, 21:32
Corroded in place over time? Could you try driving it, by starting it in gear then driving it with the clutch pedal fully depressed, to see if you can shock the clutch free?
8th November 2009, 03:50
Tried that John. Tried shocking it in gear while on the ground, shocking it while on axel stands. Braking while clutch depressed and accelerating! Still no good stuck solid.
The box will be off today for investigation.
9th November 2009, 15:07
Really pissed off. Got gearbox off. Clean all surfaces including greasing the input shaft spine which I did not do before.
Could not get gearbox back on again in the car. Found out I need the K series dowels. So may have damagd gearbox bellhousing threads and possibly clutch plate.
Engine's coming out as well now. Not much to get it out now as gearbox is off anyway. Just take the pipes, exhausts, unplug loom off etc.
Can take a good look at thinigs then and line up with some dowels.
What is it. 1 step forward, 2 steps back!
Car is fighting hard! But I WILL win in the end!
Added to the fact I need new balljoints as the balljoint separator tool decided to tear the rubber. Waiting for Marlin to let me know what car there from.
9th November 2009, 16:50
Which ball joint(s)? The lower arm balljoint is a cavalier item. I can't recall what the other standard ball joints are, but Steve C ought to know - pretty sure he tried to source some not too long ago.
9th November 2009, 17:39
I think the bottom one may be MGF as it's one single big screw in thread at the bottom.
I have no idea what the top ones are. Know the ends that thread into the wishbones are around a 13mm thread.
Waiting for Marlin to come back to me with what car there from.
9th November 2009, 19:00
Oops, I forgot you have the large screw in variety.
9th November 2009, 21:16
They look just like the ones Marlin use on the Sporster and they are a Metro upper ball joint.
Part numbers are GS269 or QSJ1060S but go for a good quality make as there seem to be some badly made cheap ones on eBay of poor quality.
10th November 2009, 05:52
Thanks for that Peter. I'll look into that metro ball joint see if it's the same. Looking good though for my lower balljoint.
16th November 2009, 16:28
Engine and gearbox out. A lot easier to whip the gearbox off at will now.
Threads are all ok. Put standard rover turbo clutch on. Instantly disengages when rotating crank pulley and pressing pedal. New helix one don't looking through starter hole.
Trying to rectify with who I purchased it from.
26th November 2009, 13:37
A little update. Tried a used Helix cover plate that someone had spare for me to try. Clutch disengages! So looks promising.
Looks like my clutch cover plate is faulty. Been sent back to Helix.
26th November 2009, 17:58
getting closer.....
26th November 2009, 19:34
Yeah getting there slowly. Had everything thrown at me. But may speed things up a little once it moves a little. I have hopefully a plan.
27th November 2009, 21:15
Were the bottom ones Metro in the end? I need to replace a few too, unfortunately the rubber perished before I even got to SVA :-(. Know the feeling of the car fiighting you. Some days its one step forwards two steps back. Finally sorted my clutch and have now found I have bent a gearchange cable already so left right is very sloppy and hard to engage,I am now looking for a better (stronger) solution.
27th November 2009, 21:31
I thought your car was at talon still David?
Need to be careful from what I've seen with the metro ball joints. From Peter's post and motor factors there are two different types of metro balljoints. Depending on year. Take yours to the motor factors to get the right taper and length of stud inthe baljoint is my advise. Not got that far yet.
Still trying to sort out the clutch!
27th November 2009, 21:40
OK thanks for the warning I have one replacement off the car I got a spare from Marlin early on just not 2 spares, will take that to my local factors.
Got my car back the other week, they worked really quickly on it, the solution they found for getting the clutch master cylinder at the right pivot point on the pedal is nothing short of ingenious very happy with it. It now drives and steers.
Getting the ride height right is gonna be tricky I gather its now designed for 3 inch's ride height, although I can maybe get 4 inch's. Think I may need to adjust springs all round, definately will on the front, but I always knew that was likely to be the case. Also toying with the thought of changing the wheels, but that will be a decision for after its on the road and I see how I like it.
