22nd August 2017, 13:13
Yup, Paul, you are correct. And, there are a changes coming-up for Oxford1360. Once they are sorted I should have a good-sized garage close to the house from ~October. Progress should be much swifter from then on......
Gary, apologies for my lack of clarity. If you could let me have a price for two of the humps that you have supplied for the passenger above.
Thank you.
22nd August 2017, 18:53
Them hinges look the dogs do-da's but what sort of door handles and locks are you going to fit?
22nd August 2017, 20:31
Thank you ...it has Landrover type slam latches and a modified Landrover dovetail catch ...I have reduced the latch area to minimize rattle .
22nd August 2017, 20:38
Apologies for my lack of clarity. If you could let me have a price for two of the humps that you have supplied for the passenger above.
Thank you.
Oxford , if you wanted 2 humps supplied separately with the same excess around them as the loose one in the picture , giving you plenty of material to 'graft' ...a 6 oz. layup and finished in grey gelcoat ......then we would be looking at £140 the pair including well wrapped postage via parcelforce.
22nd August 2017, 20:44
Glad to hear it ..your build is one of my favourites and I am looking forward to seeing the end result ....
23rd August 2017, 17:14
Interesting idea any photos?
I tried a similar arrangement on the G-46 with-out success. The doors never felt "firm" and would open with the body flexing. I ended up using a pair of small bear-catches from CAR BUILDER SOLUTIONS.
They were cheap and worked well.
23rd August 2017, 20:07
I can take some pics when young Mr. Jeff has finished painting it as latches are off at present .....they are pretty firm ...the doors don't flex much , the new uber hinges have tightened it up ......
Bear claws are really good , and you can get those door drop latch things too , to locate a door and hold it ...the ones convertible cars and lorries tend to use on the rear bodies where doors flex... this sort of thing ....
They are about £5 or 6 each from memory ...
27th August 2017, 19:16
V5c Document back from DVLA a few days ago ...all present and correct . Triumph Formosa Sports in red ..no inspection required , so Happy Days !
27th August 2017, 19:46
Jeff sent me some pictures today ...I know Graham has seen the full set , so thought I would put a couple on here ...
The car has been sprayed in Polyester reface ...this will be sanded back and then the car will be treated to some 2 pack high build primer and sanded again ...
Jeff also masked the whole of the underneath of the car , engine bay , floors etc...so no overspray should make its way onto the restored chassis ...
27th August 2017, 19:49
28th August 2017, 17:48
Car looks good.
Although one of the photos may have accidentally broken the forums nudity rules!
I'm sure all the prep work Jeff does will result in a great finish.
8th September 2017, 23:05
Fantastic! Looks super.
9th September 2017, 06:43
Wow
9th September 2017, 08:10
Very pretty, nice colour choice .
9th September 2017, 09:15
Morning Jeff excellent work again , Geoff .
9th September 2017, 09:19
Another great finish, if you want your car to have a high resale value then you need to spend big on the paint.
It would be nice to get a ball park estimate for having a GR120 and a 250 swb painted by Jeff.
It will give prospective builders an idea on what to expect for a top finish.
9th September 2017, 12:38
I was thinking the same, earlier today.
9th September 2017, 13:39
Jeff - Great work as usual, the car/paint looks amazing.
9th September 2017, 17:05
I'M VERY HAPPY WITH THE WAY SHE LOOKS ...Jeff hasn't even flatted back and polished her yet ...so she's going to look amazing ...
Mixed emotions about getting her back and fitting her up .... excited and nervous ...
9th September 2017, 17:13
Amazing is understated
