Old 15th May 2016, 19:24
y cymro's Avatar
y cymro y cymro is offline
This is looking really good. I usually prefer a hi boy look, but you're doing a nice job on the fenders, they suit it and I prefer them for once.
Are you still going for the rust look?
Shame about the gearbox adapter. I plan to use P9cho to connect an Alfa v6 to an rx box. Will have to make sure he's careful with the dimensions!
Looking forward to your next update.
Old 15th May 2016, 19:41
Looking good Andy. You will be driving it before you know it.
Old 15th May 2016, 21:15
andysharrock's Avatar
cheers guys got to go rust or full on rat I can not do with he constant washing and ho god is that a blemish on the paint. bring on the patina paint
Old 22nd May 2016, 17:32
good weekend sanding and filling starting to shape up well, itching to get some paint on her.
happy I made the changes to the running boards it's going to look well cool. starting to think of adding some flames or pinstriping or what about this
Old 22nd May 2016, 17:44
molleur molleur is offline
Looking very good!
Flames, naw...keep it simple.
Old 22nd May 2016, 18:17
Roadster's Avatar
Roadster Roadster is offline
I like the skull
To fit with the rusty patina'd look
how about this
http://www.bing.com/images/search?q=...3o0&ajaxhist=0
Old 22nd May 2016, 18:26
Jaguartvr's Avatar
Can't go wrong with flames and skulls on a hot rod.
Old 6th June 2016, 19:56
Talking it drives
well I got fed up with pushing the car out the garage to work in the sun so set about the mechanics for some reason it starts but I have No clutch.
I worked out it was not enough leverage so added a nut to the back of the pivot
this worked but caused the arm to hit the clutch not a lot but to much but some clutch improvement so I removed the nut and did this
this worked out a lot better it did not hit clutch anymore but again could be better, so I extended the piston arm to the clutch master to try and get a bit more fluid
again better but no cigar so next I swapped out the mazda servo for a landrover we now have a car the moves under its own power not me pushing it
happy days pain in the arse taking the box in and out but sorted
Old 6th June 2016, 20:08
Default paints arrived
only done a few bits on the body, bonnet split again now fitts proper job just needs re finishing
had to try the light shells
I added a skirt to the back I want to run some lights on it and a number plate.I also removed the hinges from the back door and bonded it on ,well it was never going to be used as a door and looks better
and the paints arrived so I now do need to pull my finger out
Old 6th June 2016, 20:35
Andy - This is really coming together nicely.
Congratulations on getting it driving again.
I am looking forward to seeing how this "rusty" paint works.
Old 6th June 2016, 22:07
Cool paint!
Old 7th June 2016, 06:33
hurnleft's Avatar
hurnleft hurnleft is offline
Looking good Andy. Wil it be ready for the NSRA Supernats in August?
Old 7th June 2016, 08:30
That rust paint sounds interesting reading about it
Old 12th June 2016, 18:01
Talking major car surgery
cars coming along nice I actually drove it yesterday it even stopped when I pressed the brake pedal . BUT the driving position needs work so all the pedals and the steering is back out. I have moved the steering up and right a bit sound easy but not when it's all been welded into place.
I am going to move the fire wall on the driver's side forward about 6" and lift the servos up to clear the engine
I should be able to cut some of the bend out of the pedals and make them longer, hopefully when finished it should give me more legroom and a better driving position. 1 step forward 3 back better now than later
Old 21st August 2016, 17:04
Default update
I have been doing bits in between other jobs first time in ages I have spent a weekend on her so here we go
fire wall is all back in pedals refitted and all plumbed back up I have gained about 6" in leg room so driving position is better.
I had to flip the brake pipe connections from one side to the other on the servo to get it in as it was a bit close to the exhaust. hindsight I should have made the box higher.
I also decided I did not like the dash so the had to go
new dash in or should I say in progress
The clocks are RX8 which means the electric drive from the gearbox should work for the speedo, glove box from the old scimitar
Old 21st August 2016, 17:16
Default exhaust
been fancying a side exhaust so this weekend I cut up what was the manifold and made everything shorter and to come out above the running boards
I did plan to use motor bike silencers but now I am thinking of a bit of flexi tube and a side exhaust running along the side of the running board like you see on the cobra.think rat look bit of rusty pipe running across the board would look mean. lol
Old 4th September 2016, 19:11
Default and we have a seat
well I got fed up with sitting on a box and moving it from one side to the other as I worked on the dash, so I decided to get the seat in
still work to do as always I have made the base to be removed as and when the back is glassed in. I did try the back from a VW beetle but it was taking up to much room. I have got a padded quilt cover with the american flag on going to look well when its fitted.
bit premature but had to try a bit of paint on the unfinished dash love the colour it goes on well even with a paint brush
Old 16th October 2016, 21:00
I will stop changing things one day and finish it , been watching welderup again and decided I could not live with the standard door so gone for the suicide look again.
absolute nightmare to do when I cut the body I did it on a slant thats ok till you try to flip the door hinge then it will not open it just slams into the sill.
in the end after 3 days on I came up with this
three hinges top one fixed bottom two lift clears the sill and shuts spot on, locks on order that's next weeks job.
bought some triumph silencers just hoping they will work may need to take the baffle out . bore is only 30mm the down pipe is 40mm so I needed to make a filler . que scaffolding tube
and finished looks like this
fitts a treat bit of joint compound and a clamp job dune , need to think about securing the box to the sill so it will move with the engine .
wiring loom on order I have spent hours trying to get the loom sorted for 80quid should have bought it weeks ago u live and learn
Old 25th June 2017, 19:17
Default long awaited update lol
still plodding on with the hotrod most of the wiring is now sorted we have all working lights and it starts and runs on the key and even drives . Utube link below would not let me add a video
https://youtu.be/tG0j64pSCKk
the clutch is pants only just biting and the gears are stiff so I dissed the slave and just used a monkey wrench off the clutch leaver and a bit of rope. all gears fine but only biting at the very top so looks like the clutch is on its last legs but the slave has to go.The piston on the slave dose not travel enough both ways to work the clutch properly.
so next job fit a cable clutch ebay new cable 8quid and a bit of old cross member I came up with this,woks grate but will still need a new clutch bugger.
doors rehung again suicide, open and close brill this time I made up my own door handles after the ebay ones were crap, any guesses for what they are yes I know they look rough but its a rat rod
rear lights from the states
exhaust next week I have bought two newish manifolds I am going to direct it under and out the side well thats the plan.
Old 25th June 2017, 19:18
Default my girls soaking up he sun
