Old 20th May 2015, 06:32
Well done! That's quite an achievement if you got it through first time.
Old 20th May 2015, 06:37
Viatron Viatron is offline
Cheers all, it was actually second time Mr T as first time it failed on brake balance as the adjustable brake bias wasn't set correctly.
Tried to tax it last night but the mot hadn't updated on the system yet will ne trying again later this morning
TTFN
Mac
Old 21st May 2015, 05:59
phil9 phil9 is offline
great work mac....a top motor
Old 21st May 2015, 12:29
micky1mo's Avatar
micky1mo micky1mo is offline
How well does it drive and stop of course ??
Old 21st May 2015, 13:36
Phil thanks a lot
Old 21st May 2015, 13:41
Micky
The brakes are now excellent and it pull up well and will lock up if provoked the engine is still running rough as its on a base only map and the jets are a ways off. Got it up to 60 on the way back from the MOT and the ride was surpringly good. I have the front Spax set just soft of midway and that seems tone the sweet spot as it rides nicely but doesn't wallow. The tears are set just firm of midway and again that seems to be working.
Next job is to get it on the rolling road for a tune up and I should then be able to stretch its legs properly.
TTFN
Mac
Old 21st May 2015, 14:31
micky1mo's Avatar
If a car "feels" right it normally is right.
Your racing history should set you in good stead to see just how well you can stretch it's legs.
Old 24th May 2015, 08:07
Mac - Belated congratulations on the MOT.
You have joined a very exclusive "club", as there are very few Cordite/Navigator kits actually on the road.
Good luck with the last few details, Paul.
Old 25th May 2015, 07:40
Paul,
thanks but have hit a small snag as i tried for about 3 days to tax it on line before noticing that the MOT tester had got one digit wrong on the reg! Spoke to them on Friday and they tried to contact VOSa to get it changed but couldn't get through so will try again tomorrow.
TTFN
Mac
Old 25th May 2015, 13:15
To anyone spraying at home I hope this helps.
Please bear in mind the following
1. I used a high solid 2 pack paint commonly referred to as truck coat, it goes on thick and does take a while to cure fully but if your spraying conditions aren't ideal (like mine) it allows you the luxury of having enough paint on that you can correct most runs, orange peel etc. The specific product i used was Lechlar 29155 also referred to as LS155.
2. I put about 5 coats on and could probably have reduced the peel by thinning a little more but that would have encouraged more runs.
3. This is just my experience some may disagree and if you follow my lead don't blame me if it goes all Pete Tong!
4. Truck Coat by the very nature is not conducive to producing a mirror finish shine, if that's what you want then this isn't for you. Me personally? I wanted a period finish with some shine and lustre but wasn't that bothered from the start about a mirror finish.
Goin back a bit this was the finish out of the gun:
Very orange peeley to say the least.
After about a week I started to flat back starting with 800 on a small solid block fro runs first then moving up to 1200 to start removing as much of the peel as possible. I used water in a spray bottle with literally 2 drops of washing up liquid to help reduce clogging. After the 1200 i moved up to 1500 then 2000. In hindsight i could probably have gone straight from 1200 to 2000.
Part way through this process you will definitely think you have totally cocked it all up:
Keep persevering though just take it slow and easy and changed your sanding pads regularly. Eventually you'll end up with this:
A smooth flat surface but with minimal defects
Next step was a good wash with nothing more than clean warm water twice to ensure that any left over contaminants are removed.
After letting it air dry I then started (This morning) to cut back using Ferecla G3, be warned that the product you can buy in Halfords in the black bottle is not the same as the pukka stuff in a yellow bottle available from your local paint supply place.
I found that ToolStation did some very cheap foam pads and polishing mops and having used them I think they were fine and dirt cheap.
First i soaked the new sponge in clean water then squeezed the majority out by hand followed by spinning the wet sponge on the polisher to remove most of the remainder, you want it damp not wet.
A few dobs of G3 on the panel and then swirl it around with the sponge before you start. Start at low RPM, I'm using a cheapo Clarke polisher and started on setting 1. Keep the sponge flat to the surface and move slowly, don't linger or you will burn the paint, sounds scary but just take it slow and steady. after the majority of the G3 has started to dissapear I then up the rpm setting to 2.5. If things start to get sticky then stop and spray a fine mist of water on the panel , this helps keep the temperature low and acts as a lubricant. Keep going until your left with just a light haze on the panel. Now remove any remaining haze with a clean cloth and inspect. If necessary then start the G3 steps again! Its not a quick job but the results are worth it.
Just this morning the rear of my car has gone from a totally flat fin ish to this:
And a close up of the same are to show its not just 2 foot good :-)
Very close up you can still see some very faint swirls and I will decide after finishing with the G3 wether or not to go up to maybe a G10 for a final finish.
Hope that helped someone
TTFN
Mac
Old 25th May 2015, 13:24
Some links that may be useful:
Lechlar Spec Sheet for the paint:
http://www.express-paints.co.uk/content/291551.pdf
Polishing stuff from ToolStation:
http://www.toolstation.com/shop/Powe...+Bonnet/p80677
http://www.toolstation.com/shop/Powe...+Sponge/p33265
Feracla G3
http://www.amazon.co.uk/FARECLA-BODY.../dp/B003JI745O
TTFN
Mac
Old 25th May 2015, 16:44
Well that's it, I have decided that G3 is enough! mainly because my body just wont stand up to going over the whole thing again with G10...
I have also just given it a coat of Mer and cleaned the interior. List of jobs left is now:
1. Clean Wire Wheels and tyres
2. Finish Fuse Box Cover
3. Finish Gear lever cover
4. Sort out the holes left from the front mounted indicators.
5. Make a cockpit bumper for between the humps.
6. Make a finishing piece for behind the steering wheel.
7. Paint the mouth cream
8. Fit the grill
9. Fit sticky front number plate.
10. Fit headlamp chrome trims
11. Paint Navy Blue pinstripe along border of cream panel.
Done!
TTFN
Mac
Old 25th May 2015, 17:10
Nike55 Nike55 is offline
Great job Mac..
Old 25th May 2015, 20:49
1iTim's Avatar
1iTim 1iTim is offline
Looks fabulous, be proud of that! Are those beetle indicators at the front? They look good
T
Old 26th May 2015, 07:53
swifty's Avatar
swifty swifty is offline
Nice work Mac the car looks great.
Just in time for the summer, happy days.
Old 26th May 2015, 10:58
hurnleft's Avatar
hurnleft hurnleft is offline
It looks lovely. Hope we get some nice wether now so you can enjoy the fruits of your labour.
Old 26th May 2015, 13:25
Tim got the side mounted indicators from Holden.co.uk
Thanks all for the comments
Bit of a pain today as the garage called and it's going to be easier to retest than to get the current MOT cert changed to the right reg number doc obviously but a pain none the less. It's booked in for Saturday morning so hopefully I'll be taxed and legal by Saturday lunchtime 👍
TTFN
Mac
Old 27th May 2015, 14:56
Nice one Mac, the car looks really first-class!
Old 27th May 2015, 16:21
Mac - Thanks for the guide to making paintwork shine, as it seems to have worked well for you.
Good to see you have been following the Scottie22/Hulk Hogan "Build Bigger Arms" programme.
Old 15th July 2015, 05:56
Just bumping this thread back up to Page 1.
Mac's News Here:
http://www.madabout-kitcars.com/foru...ead.php?t=5513
Car's Ebay Advert Here:
http://www.ebay.co.uk/itm/2218200588...84.m1555.l2649
And here are some extra photos from the ad.
Anyone you has followed this build will know Mac did a really great job.
