15th February 2009, 06:26
Opened up my "working" box yesterday that I had been using on the Marlin.
Found this.
Diff failure. Bearing has sheered the diff. Common on the type A diff's. Lucky I had another type B one spare in another gearbox. Which was stripped before this one.
17th February 2009, 17:45
Hi John,
Can't help but thinking that you are a free test bed for Marlin engine fit?....or are they helping you out on this one (seem to remember that a new engine would have 'free fit development' done by the factory in the sales pitch)
..anyhow, (if misses Limpabit isn't too close) what's total cost on the car now?.....just intrigued as to value vs fun vs performance vs elise....
ATB
Rich (longing for the sun to shine)
17th February 2009, 18:09
Hi Rich.
Getting no help from Marlin. Though I have not asked for any.
Ian (merlinman) has done the mounts as I have no experience with welders!
This is not a stand VW build either (Am I trying to justify the costs. ). Lots of after market goodies from standard. Like a T28 turbo I had about waiting to go on the Rover engine. Know going on this.
But with that, comes baffled sump (as a safety measure, aftermarket ECU, gearbox rebuild, Rover gearbox conversion, etc ,ect.)
Not added it up accuratley at the moment but looking at th 3K mark I would have thought.
Yes at the beginning, it may have been worth getting an Elise. But with a broken car, thought I knew the car better than anyone as I built it. I could have put another Rover lump in it for a couple of hundred maybe. But decided ages ago, I was looking for a different engine, more modern.
I made the decision with the VW as this looked like a good modern alternative.
14th March 2009, 09:10
John,
Looking good mate hope you get it cracked for the summer!
Craig
19th April 2009, 20:41
Ok a little update. Well quite a big one!
It's taken quite a bit of time, but the gearbox is now beefed up and working. main problem I had in the end was getting the gearbox shimmed (Rover don't do them anymore). But now all together and working.
A picture of the gearbox ready for the case. All steel caged bearings. Type B diff so should have better grip than the broken one above!
Custom flywheel locking tool! The bolts for the adapter plate was not the ones I ended up using. Ended up routering out a litttle and using cap head bolts to sink the bolts slightly.
Custom 6 paddle race Helix clutch.
Walbro high flow 225 PL Fuel pump in Rover case.
And engine in car. Could not use MGF mount as mounting was way off.
Next on the agenda. Complete water system, mount plumb in oil cooler, and electrics. Should not take too long. Then ready for first start.
Then lastly, charge cooler setup.
9th May 2009, 15:00
Well all I can say is YEEPPE!
The engine fired up for the first time today. All be it with the electrics all done temporary.
Fix numerous oil leaks along the way.
Need to do electrics permanently now and finish cooling system.
A little video.
9th May 2009, 21:44
well done look forwards to seeing it on the road.. it certianly sounds the part.
10th May 2009, 19:41
Kit Car Dreamer
That looks awesome, and I admire your comfidence!
I noticed you mentioned a charge cooler. I was going to start a tread about this, I wasn't sure if it had been discussed yet - the search facility on this site doesn't work very well....
What's your idea?
11th May 2009, 05:32
Definatly chargecooler for the turbo cars.
Standard intercooler and position is useless.
Toyed with the idea of a big front mount (have pulsar intercooler already) but never fitted. Thought it would introduce lag as well as problems and looks on mounting it.
So....
Idea I have is I bought a cheap chargecooler off ebay similar to this but not at that price!
http://cgi.ebay.co.uk/CHARGECOOLER-W...3A1%7C294%3A50
Bought this pump.
http://cgi.ebay.co.uk/Charge-cooler-...3A1%7C294%3A50
Going to use a mocal oil cooler as the rad with plenty of antifreeze as I could not get a chargecooler rad for the dimensions and price I wanted!
And mount it at the rear bulkhead ( have plenty of space in the engine bay now.
But I know Matt on here has gone chargecooler route with the T16. PM him.
21st July 2009, 22:05
Originally Posted by limpabit
When I drove the car round Woodbridge, the car handled ok. Springs need to be harder, but seemed ok. It seems more funny on normal roads???? But I see what you mean about power.
I intend to have it on a roading road to check these things as that is where I picked up my engine was rocking!
What weight of springs did you go with in the end?
I am looking at AVO coilovers, as i have a trade account with them. However, i dont know what weight of springs i should be going with. I want firm firm, predominantely track type ride.
21st July 2009, 22:41
The car doesn't need to be firmly sprung to work on track, but, and this is by no means intended to be argumentative, if you really want the car to work on track, it's my view that you need to start considering the geometry (I don't mean camber / caster / toe), and get that sorted. The roll centres, jacking, pro-dive, pro-squat, etc - these really need to be resolved before the car is a truly capable track tool. Fast road / track work on a stock car, is erm, interesting, in a slightly unsettling way.
21st July 2009, 22:46
Surely, everything geometry related is adjustable once built?
(But do correct me if needed)
I am looking to buy springs that are realistically suited to the 1.8t engine in the back. I know marlin have their own custom springs made, but i'm sure these are for the rover engines and possibly less weight than the 1.8t vag unit.
You mention "fast road / track work on a stock car."
can you explain a little more please? )
21st July 2009, 23:16
My chassis, which was produced in March 2006, had from factory some characteristics which I didn't like. I found the car unpleasant to drive, and very unpredictable.
My car is now quite different, and I can deploy the power with reasonable confidence.
http://www.madabout-kitcars.com/foru...ead.php?t=1639
21st July 2009, 23:49
Wow,
you have made a few mods to your suspension.
I think i shall concentrate on getting the thing built and running first.
There obviously seems like there is room for improvement and luckily i am fairly handy with the old welder.
What was the view from Marlin on your alterations?
adam
22nd July 2009, 06:37
Hi Adam.
I upgraded the front springs to 220 due to the ones supplied too soft. Once the car is on the road, I shall be taking the car to track developments as John did to get a professional assesment with weights etc. As car had a Rover Turbo in it before, what to get the spring rates right instead of keep guessing.
As for engine mounts etc. I had the Rover running gear before. MGF gear change, gearbox etc. So mine is based on Rover running gear with the 1.8T bolted on. But beefed up the gearbox internals to cope with the extra modded power.
Mine are all done, just little odds and sods to do before I take the car to get exhaust made. I'm going for around 300-350 mark on standard internals for now. After experience with 200 BHP, this will be plenty. At 200BHP, it was frightening. So god knows what it will be like like this!
If it was me going for the power you aiming for, I would get all the major components built up and take it to track developments.
The engine was sick when I went to woodbridge (170BHP at the wheels) before it went to heaven. It managed 120 MPH on the straight (about 1/4 to 1/2 mile).
22nd July 2009, 07:30
I had a go in a Supercharged Ariel Atom a while ago and that kind of power in such a light car is awesome!
22nd July 2009, 12:02
I didn't have that conversation.
22nd July 2009, 13:45
that answers that then!
27th July 2009, 19:33
Thought I would give some update as it's been a little while.
Boost hoses and chargecooler fitted. Hoses not jubilee clipped yet as I need to complete the water hoses for the chargecooler (waiting for rad)
Polished inlet and new expansion bottle. Together with shiney chargecooler filler.
Oil cooler fitted. Electrics looks worse than it appears. Just lamber to solder in (but can't do this until exhaust is done. Gentral clipping on wiring to do for now. When mapped and all wiring tested, the will go in conduit. Just in case I've missed something!
Things to do.
Accelerator to be sent off (too short)
Jublee clip every thing that is left (a few water pipes and boost pipes)
Fit slave cylinder and battery tray.
Fit driveshafts back together
Fill cooling system and check for leaks. Same for oil system.
Fill engine up to temp and see if Rover gauge displays correct coolant temp!
This I hope to complete withing the next 2 weeks. Maybe not accelerator cable (sending it off to get done).
Hopefully off at the end of September to get exhaust made.
27th July 2009, 20:00
That looks brilliant!
It will be a looooong time before mine looks anything like that.
Did you make the engine mounts yourself?
Were you running the rover or vw gearbox?
