Old 20th April 2020, 20:39
jones jones is offline
I think you have been but just in case you haven't sprinkle water on the concrete to also help keep the dust down whilst spraying.
Old 21st April 2020, 18:33
IanA's Avatar
IanA IanA is offline
Sad to say but mine is going the same way after about 18 months. Stored outside but seems to have come on suddenly with the recent warm weather. It's probably down to keeping it in gel coat for so long before having it painted. I can't see me getting anything done about it this year so when the time comes may try to provoke it with a bit of gentle localised heat. It will be interesting to see if anything happens to the doors. If not, then my "damp" grp theory is probably the most likely reason.
Old 24th April 2020, 19:49
I had similar happen after flatting primer with wet & dry (used wet). Since that problem I've always used the W&D dry - it's not as effective and needs brushing or replacing frequently but I haven't had it happen again. Maybe a coincidence, but I suspect it takes several days of hot sun / dry conditions to dry before putting on top coat if wet flatting is used?
Old 25th April 2020, 07:08
WCA – Good luck with your paint job.
Although slightly disappointed you didn’t use your axe to tidy up any blemishes.
Take care, Paul.
