I'd also think twice about using belts from a scrap yard. Chances are they'd have been involved in a shunt and may not work as advertised a second time.
Most people don't appreciate how much belts are designed to stretch in an impact. A friend of mine was racing a Westfield and ran into the tyre wall at the start of Gerrards (Mallory Park) due to a chassis failure. He broke the chin piece of his helmet on the steering wheel, which means the belts extended about 18 inches!
That's how they're designed. The aim is to decelerate you as gently as possible, the same as a crumple zone. If your heart hits the inside of your ribcage at more than about 60G it will stop! That happened to amateur race car designer Dick Harvey when he ran into the end of the pit wall at Mallory in a Formula 750 race. Only the prompt actions of the medical officer and that of the ambulance crew who together restarted his heart a total of five times saved his life. On the road he'd have been dead, but on the track he survived and was back racing the same season once a broken leg and new chassis were dealt with.
I examine belts quite carefully when I buy a used car (never owned a new one I didn't build). An old trick is to run a lighter down the edge of a frayed belt to get it through an MOT and you can often see friction damage where a belt has run through a buckle fast due to an impact. If they've done their job once, they're not really up to doing it again.
