4th September 2007, 10:54
Rich,
The v-tec step with the I-vetc is pretty mild (at least it is in an EP3 Civic) as a product of the variable inlet cam. There is still a slight spike, but the engine being NA works in our favour. I reckon we can drive around v-tec and with the hondata we can certainly dictate exactly when it comes in – boost in my experience is far harder to adapt to.
That said, I know the moment I try and drive mine with any vigour on track, I’ll spin many times! I think as modern cars are so often FWD, and even when they are RWD they’re fairly heavily pacified, very few people can really drive properly. Certainly my skills are pretty poor - the last time I was on track I spun a FWD 360 deg at 90mph, (much to the amusement of my friends watching!) due to LOO, and not reading the track surface very well (damp patch mid-corner).
Whilst I’m not worried per se about driving my car when it’s done, I’m going to tread very very cautiously for quite some time! John’s story has certainly confirmed what I expected – very square footprint, mid engine, low inertia, gives the car an ability to spin quickly when it goes!
On a side note, I hope there will be quite a few 5EXIs at Llandow, as I would really like to see one going at a respectable pace on track – I went in Dylan’s road car at Brands Hatch a couple of years ago, but that is now quite a distant memory. I reckon the 22nd will be quite an amusing day – my car has a paultry 135bhp / ton, so I expect to be little more than a rolling roadblock, with overheating brakes and floppy suspension!
Cheers,
John.
4th September 2007, 11:36
Fingers crossed, I might even see you there in mine. We will see.
A lot of work to be done, but parts could be arriving sooner that I thought....
Boost will be turned down for me though. Unless Mark gives me the nod on the track. Learn from others.
4th September 2007, 12:04
The Vtec does kick a little, but nothing like a turbo, unless you change the cams, my mate fitted Toda Killer cams in his S2000, that kicked when you changed up through the gears, now its an animal but fine if you are on the Vtec but if you floor it in a straight line the back stil kicks when the cams come in. Cant wait to get my brakes plumbed in so I can take it down the road and give it a little blast.
4th September 2007, 12:27
S2000 is more agressive though, as it has static cam timing. The I-vtec can can adjust the inlet cam phase, which smoothes the torque curve through the revs.
http://www.twminduction.com/Throttle...s2000_dyno.jpg
Pretty aggressive mid-rev punch.
4th September 2007, 12:56
Arh that makes me a little happier knowing that it should be smoother, well hope so give me time to learn how to drive. Got to start learning quick only have the 2008 season before the new engine goes in.
4th September 2007, 17:06
Well I cant comment on the type r marlin cars as have not been in one at v-tec engagement. Mine is drivable but nowhere to try it properly.
What I can comment on is the type r elise which is as about as similar in weight as we are going to get.......v-tec came in quite hard and with a relenting surge.
You could most definately feel it kick in esp in 2nd and 3rd gear as the wheels would immediately start to scrabble (spin in 2nd) and that is with 225 tyres on the rear. Think from memory v-tec was set at 4k which i have been told to set mine too due to the lightness of the car
Craig
4th September 2007, 18:02
Well whoever is the first to get a good run up and down a road, with the k20 fitted please let me know how you got on. Ill be running mine up the road end of october, once the suspension work has been done. Is any1 looking to get there before me or does it look like im the ginny pig,
Dont tell Nick though.
Jon
4th September 2007, 18:04
If you open her up, just make sure there's no concrete about. Try a field or something.
4th September 2007, 18:14
Dead straight road just in a housing estate, and most people dont like cars or me in fact so shell be fun
4th September 2007, 21:51
Well as we're heading off topic pretty fast, I might as well keep the momentum...
If Rich's talk of SVA is anything to go by, his car will be roadworthy before Craig's, or mine. Where Jerry is with his, is a mystery, but he can't be far from finished from what I've heard.
Define proper drive. I've hit vtec in first, which was a bit of a non-event, as all that happened was that I got masses of wheelspin. I've had my car up to about 40 in 2nd, totally legally.
Going back on topic... ever wondered why Elise / Exige / VX220 have an open diff? Going on John's experience, imagine how quick you'd have to be to catch a car with an ATB diff!
4th September 2007, 23:51
Well, I've somewhat optimistically booked my (first!) SVA for next Thursday in Shrewsbury. Being ready is going to be a bit of a challenge (worked through till 11 tonight!), and there will certainly be things to finish afterwards - mostly final bodywork fettling and paint-job. I'm desperate to get it on the road though!
There's often discussions about this on lotus forums. The conclusion seems to be the LSD makes the car a bit slower round a track, but with an advantage on autocross. I've seen some comments that the handling on the limit becomes less delicate with the LSD but may well just be that LSDs get fitted without other adjustments to the alignment.
Still, it would be nice for the donuts :-)
Richard
5th September 2007, 06:09
Mine is open diff with no torsen as it's a normal NASP box from a 2.0. But don't even think that would have help me. Have a gearbox that needs bearings with a type b torsen diff (latest Rover fitted to the 620 TI.) Was going to be a winter project. But might get it done sooner rather than later now.
5th September 2007, 08:10
John, this conversation has yeiled quite the opposite to what I expected. I understood road going Elise's and VX220s don't have any form of limited slip, as with a LSD / ATB diff, when traction breaks, both wheels do so at the same time. This makes for a much quicker change in rear adhesion that if the inner wheels spins up, as is the case with an open diff.
Curious.
Rich - good luck. I reckon I could get mine to SVA standard in a couple of weeks, but I know if I put it for SVA "unfinished" (in my mind), I'll be too busy driving to bother tarting it up! So I'm getting everything nailed, then I'll put it in for SVA. 2 months should do it. I HOPE!
5th September 2007, 09:06
They don't! I think that we are talking about the Jdm elises which come with lsd but everyone I have spoken to about the Jdm engine in an elise confirms what Rich stated. They are very unsteady on the edge with the lsd kicking in quite abrubtly on corners, causing spins etc
I may be wrong but I dont think any of us so far have purchased a Jdm engine? If anyone has they will probably also find the gearing crap in 5th and 6th as this is much lower in the Jdm
Craig
5th September 2007, 09:12
Im looking at a sequential gearbox at the moment with LSD for the new engine, not sure on ratios or what it is likely to be like, hoping it will be good, well for the money atleast, but it cant be that bad if its used in BTCC and Britcar?
Im still trying to work out if LSD is need though, some say its a must others say maybe or no.
5th September 2007, 09:21
Jon I suggest you do a search on seloc as there is not much positive comments on there about the Jdm lsd most that dont track their car dont notice but those that do track them notice very unsettling characteristics when pushing around corners
From memory I remember something about car being so light that the lsd kicks in sharply
Craig
5th September 2007, 09:45
Thanks Craig, I'm going to keep saving well i look as I dont have a spare 15k to go and buy one from Italy. I'm going to wait and see what the motorsport guys come back with from Honda, A) they are just down the road, B) they do the gearbox for all the racecars C) few mates work there so are asking people to look into it.
Most people think I shouldn't need to fit it because of the weight of the car and the power etc but they want tell for sure if it does or not.
Once ive got an answer ill make it public
5th September 2007, 09:54
Craig
Rich said the opposite - it's more stable, which I found very very odd!
Having driven open diff, and lsd equipped RWD cars, the open diff cars start to wheelspin earlier (but only spinning the unweighted wheel), while the lsd equipped cars keep gripping for longer, but when they go, they whole back end goes as one, and things happen much faster.
The JDM lsd is meant to be a bit aggressive, which further adds to its ability to make driving on the limit pretty hard to balance.
Curiously an ATB diff on a FWD car is a god-send however, as it reduces understeer, and makes anything with an ounce of poke far faster and more stable leaving corners.
5th September 2007, 10:59
Originally Posted by Ric H
There's often discussions about this on lotus forums. The conclusion seems to be the LSD makes the car a bit SLOWER ROUND TRACK, but with an advantage on autocross. I've seen some comments that the HANDLING ON THE LIMIT BECOMES LESS DELICATE with the LSD but may well just be that LSDs get fitted without other adjustments to the alignment.
Richard
John, what you have said about the front wheel drive is correct and having just refreshed my memory on seloc, what they are saying is that the JDM engine was designed for a front wheel drive car and does not work well in rear wheel drive as previous comments but another type would prob work well given the money
I read in to Rich comment in that he meant not as much feel and composure maybe read into it wrong
5th September 2007, 23:23
That's exactly what I was getting at Craig, yes. I should make it clear this is all from browsing around and reading up - not from personal experience. I don't think I've ever actually driven a LSD car myself, front or rear wheel drive. And I've never been on a track...
I know I had a nitro-engined radio controlled car once with a *zero* slip diff (or, ahem, no diff) and it handled like a mad dog
