Press the bearing into the upright, then the drvie flange into the bearing, but be sure to press against the inner bearing shell at the same time as you press the flange in.
I wouldn't worry about the seals.
Oh, and if you've got an old bearing shell stuck on a drive flange, create a flaw in it with a dremel or similar cut off tool, and then smack it with cold chissel.
