28th November 2018, 13:15
Originally Posted by molleur
Thought you might.
Looking good. I almost ordered a Fiorano but opted for the 250 SWB instead. Spitfires are pretty long in the teeth and replacement parts very dear on this side of the Atlantic.
ahh cool - I was the opposite - I almost ordered a 250swb when they first built it - then found mine and opted for that
28th November 2018, 13:38
I still would want a Fiorano as well!
And a JZR trike, and another pre-lit Westfield.
28th November 2018, 22:18
Never mind, I'm sure that you will learn to live with your mistake
28th November 2018, 23:23
Originally Posted by jaguartvr
never mind, i'm sure that you will learn to live with your mistake
lol
4th December 2018, 14:49
4th December 2018, 15:07
Amazing transformation. Good work.
Do you intend to make a mold & new part, or simply fiberglass and scrape the foam out?
4th December 2018, 16:38
cheers, I'm going to have a mold made so that it's fully fiberglass and not just made of lots of filler - plus if it ever gets damaged I can have another made easily
4th December 2018, 16:40
It looks quite good Paul. My only concern is whether the smaller aperture will flow enough air for cooling. Although, I suppose twin electric fans would redress that problem.
4th December 2018, 16:45
Oh, and here's a shot of my car on th TSCC stand at the recent NEC classic motor show
4th December 2018, 17:23
Very nice! Good move to have a mold made of the new nose.
Really improved the "look".
4th December 2018, 19:48
cheers - that's what I'm hoping
7th December 2018, 16:49
Got a coat of primer on to see the shape better today -
7th December 2018, 18:11
That's the ticket!
7th December 2018, 20:07
Brilliant. The badge hole looks like the entry point for the starting handle.
7th December 2018, 20:14
It does.
Simply stuff a section of rad hose in the hole and it will look the part. Even a hunk of PVC tube would work.
8th December 2018, 18:22
A piece of white perspex with a warm white LED behind it, Wolsey style.
10th December 2018, 15:46
Hi guys ... ok opinions!!
please see the pictures below. - this is the 'Buck' if you like - it's shaped with foam and filler and then just painted roughly .... so it's not the finished front - if I think this is working then I'll then take this to get a mould and copy made.
However I think the grill apperture is slightly off centre .... I'm not sure wether I'll be able to do it any better if I try and make another 'buck' ... so the question is - is this good enough or do I go to the time and expense of making another buck in the hope that I can get it slightly better next time?
thanks
10th December 2018, 17:56
Difficult to tell from the pictures, but from experience, you really need to make the call yourself.
If you're happy with the way it looks then go ahead and have the mould and new nose made.
But, if you think there's any chance that you'll always look at the front and wish you'd done it differently, then bite the bullet and keep changing it until you are happy with it. Otherwise you'll be stripping it down and starting again in a year or two anyway.
10th December 2018, 18:11
Looks good but thre grill needs to be in better condition. How about a modern Jaguar S type grill, should be a lot cheaper.
Would look good with a big pair of F off chrome headlights
10th December 2018, 18:27
cheers guys .... I think it's actually the grill that's not symmetrical, it must have had some sort of 'bump' in the past I think.
.... but I sort of like the fact that it's a bit battered - I think makes the car look more authentic .... like an old vintage racer (and it's cheaper than buying a immaculate mk 2 grill)
Currently Active Users Viewing This Thread: 19 (0 members and 19 guests)
