18th October 2011, 11:56
Are you sure you have a 2 litre lump?
I've been trying to find a site that lists when changes were made to engine spec by engine number, but the best I could find was this one that looks solely at the prefix letters:
http://club.triumph.org.uk/prefix1.htm#Vitesse
Clearly, so long as this isn't duff info, if your engine number starts 'HB' it's a 1600 but if it starts 'HC' then it's either a mk1 or mk2 two litre.
As for the manifolds in your pic, will the angle of the carbs cause clearance issues under the bonnet?
18th October 2011, 19:20
Thank god, it says HC
So all those bits i have are not wasted... Couldn't of told the wife...
But i do have some rear shocks that aren't required!
19th October 2011, 07:30
Hmm, I'd fit those rear shocks if I were you Gary.
I like your thinking: there's an obvious weight saving to be made by deleting non-essential fripperies from your chassis like the shock absorbers and brake calipers, for example, but the trade-off is that you might find the ride gets a tad unsettled without them.
24th October 2011, 15:20
Question. I have a 71' mk.2 Vitesse and i have been looking at the Canley schematics trying to identify my inlet manifold, but i don't recognise it. Please see attached.
Hi
There are two main ways that a 1600 or mk1 cylinder head differs from a mk2, firstly the mk1 had separate push rod tubes pressed into the casting, the mk2 has tunnels in the casting. Also the inlet ports were raised to improve breathing so a 1600, mk1 head has the inlet and exhaust ports in a straight line whereas the mk2 has the inlet ports above the level of the exhaust ports giving a zig zag effect. The head in the photograph appears to be a 1600 or 2 litre mk1. Hope this helps
24th October 2011, 16:17
Thank you, Mr. Bond
it says HC on block, i would like to know how a 71' ended up with a mk.1 block...
24th October 2011, 20:15
Triumph Bitsas
Hi Gary
The meccano type construction of the herald based cars lead to a lot of people mismatching parts. I once had a spitfire 1500 which handled rather worse than I would have expected, I found out after a bit of detective work that someone had fitted Herald half shafts which are quite a bit narrower resulting in a back axle with toe out. Your engine would appear to be a mk1 2 litre and there is nothing wrong with them, on paper they are slightly less powerful than a mk2 engine but in a lightweight package like a Sammio I would imagine it will do the job. I hate to ask but have you checked the rear suspension on your Vitesse? It has got the rotoflex couplings not the swing axles hasn't it?
24th October 2011, 20:34
oh yes...
i have rotting metalastic doughnuts but i have a full rebuild kit for them. I even have rear shocks, not having noticed the telelever units? can i rebuild them or should i just exchange! heres a pic
24th October 2011, 21:25
I'd exchange them if poss, Rimmer Bos can do that I think. You can get conversion kits to fit telescopic shocks if you want adjustables I had this set up on a Burlington Arrow and that worked well. Rimmer Bros supply them as well.
http://www.rimmerbros.co.uk/Item--i-GRID008052
Happy Building
25th October 2011, 09:23
Thank you, Bond
I will get them, save wasting the shocks i bought. just need to look at gasket set to see what won't fit as i bought for a Mk.2. i also want to do alternator upgrade, any info.
25th October 2011, 11:05
found this if its any use
http://www.quillertriumph.co.uk/Quil...conversion.htm
DYNAMO TO ALTERNATOR CONVERSION
Car not starting as easily as you would like?
Battery letting you down?
Add uumph to your charging circuit by converting to a modern alternator system charging at 45Amp - the dynamo we supply with this kit puts out a hefty 45Amp which is an upgrade on the standard 36Amp units available
This kit supplies those parts required to convert (including wiring diagram and fan belt) as well as the alternator itself. Fitment is a simple job of bolting on the alternator instead of the dynamo and re-routing wires.
The kit contains a new fanbelt & alternator, everything else is secondhand but repainted.
We can supply kits suitable for Spitfire, Herald, Vitesse, GT6, TR5
Kit is priced at £129.00
probably cheaper ways to do it
25th October 2011, 11:40
Similar kit also at Rimmers for £119 http://www.rimmerbros.co.uk/Item--i-GRID007242
Although both of those seem expensive for what you actually get in the kit when you consider that an alternator on it's own is only about £50ish
Mine was already (badly) converted to an alternator, but i had to re-do all of the wiring to tidy it up and I also fitted a new alternator and fan belt and that only came to about £60/£70 in total.
If you want to weigh up if these kits are good value for you, or if you can diy for cheaper, have a look at the instructions i followed to help you make your mind up:
http://www.northcotts.clara.net/tssc...lternator.html
25th October 2011, 13:57
Is it worth it,no hrw, wipers etc unless you going for some heafty spot lamps, my little ol' dynamo works fine only a few lights to power I did stick my meter on the thing when I fitted the lights switched every thing on "no trouble" but if the dyno needs replacingthen a upgrade is a good idea, (canleys exchange dyno £40ish)....PAT
25th October 2011, 14:44
You're probably right, Pat
but i am changing everything... can't help myself, spending all ebay earnings!
25th October 2011, 16:33
Worth giving Canley's a ring: Can's say for certain but it looks like you can put a kit together from their parts for under £100 with a 55amp alternator.
https://www.canleyclassics.com/searc...ternator&ptno=
27th October 2011, 21:33
size of seats
would this size fit the sammio, 66cm h x 53cm w approx overall with a seat depth of 46cm? have seen something i would like to re upholster myself...
28th October 2011, 11:22
I'd say it depends on how you fit them,but those do sound a bit too tall and a bit too wide!
FYI Here's the dimensions for mine, i got the ones without the headrests and mine are incredibly "snug" width wise and it took lowering the floor and tilting them to get them to fit height wise
http://www.sportseats4u.co.uk/images...Dimensions.jpg
28th October 2011, 11:34
Hi I've a couple of school chairs for nufink, as Gary and Mike are doing seat shells reasonable Pic on Skippy post wil be cutting the backs down then trimming..PAT
29th October 2011, 16:29
In the past I have fitted 2cv alternators on cars where space is crucial....they wouldn't suit a heavy load , electric everything cars , but will fit a Sammio just fine....they are diddy little items and can be tucked away quite nicely....about £60 ish from German Swedish ( GSF )
1st November 2011, 12:57
just started blog
Only a couple of pics at the moment, need to get upto date.
http://garyssammiospyderbuild.blogspot.com/
1st November 2011, 18:00
Link doesn't seem to work, is it just me?
