Old 21st August 2017, 22:24
Mike Mike is offline
Originally Posted by jeremy View Post
Hi Mike, thanks for that info. I havent had much time to fully investigate yet, but have a few things to check. I know it is a 12 volt guage as is marked and I have the original fitting instructions. I am wondering if the difference in reading on ignition (11.5 volts) and starting (alternator 14 volts) makes a difference. Also the 2 coolant sensors-blue one to ecu, and black one to guages can be checked by taking live readings from my obd diagnostics. I also have the use of a thermal imager which can read any part of the engine for temperature, which may be useful, and I obviously need to check all my wiring again. May get a look tonight when little one asleep.... he wants me to drive him to school in it soon... no pressure!
Jeremy
Are you using the BMW sender connected to your Smiths gauge, or have you fitted a Smiths sender?
