Old 8th March 2011, 06:37
GlenSL GlenSL is offline
GlenSL is on a distinguished road
Default 325 or 525??
Hi guys, not sure if I am barking up the wrong tree here but I am hoping someone can shed some light. With regard to engine and gearbox etc is the 525 the same as 325?
Thanks Glen
Old 8th March 2011, 07:31
GreatOldOne's Avatar
http://www.unixnerd.demon.co.uk/bmw.html
Code:
Gen Model Body styles   Engine
E30 325i  All           M20
E36 325i  All           M50
E34 525i  early Saloon  M20
E34 525i  late Saloon   M50
E39 525i  All           M54
I'm assuming that M20's will share a common gearbox, as will M50's. No idea on M54s.
Old 8th March 2011, 12:40
MartinClan's Avatar
Although the basic engine and gearbox will be the same there's no telling what differences there will be on the engine anciliaries and gearbox ratios. I would look carefully before plumping for an M20 engine and gearbox from a different series...
IMHO
Old 8th March 2011, 17:02
Mike Mike is offline
Thanks Glen
Glen
I think there will be differences with the gearboxes for sure, as there are differences within the 3 series range itself - some have sport close ratio gear sets, and others do not. Also I think the sump positions could be in different places? I have an M50 and have seen photos of M50s with the oil dip stick in a different place and a very different sump - I put this down to probably being that they came from different series donor cars, but that is only a guess?
As Robin says, do your research before you commit.
Old 8th March 2011, 19:12
Simon's Avatar
Simon Simon is offline
Simon is on a distinguished road
I would agree about researching beforehand but the M20 engine and gearbox in my Cabrio were from an E34 525i and I didn't encounter any significant problems (bearing in mind that this powertrain option was never originally intended for the Cabrio !).
As people have already said, I think that the engine and gearbox are fundamentally the same between the BMW 3 and 5 series.
I'm not sure what the ratios are in the 3 series but the E34 525i ratios are as follows
1st = 3.83
2nd = 2.2
3rd = 1.4
4th = 1.0
5th = 0.81
Final drive = 3.73
I assume you'll be using the BMW final drive, but the above ratios worked very well with the Sierra 3.92 diff in my Cabrio as you don't need the long gearing of the BMW (100mph is scary enough let alone 135mph !).
The reason I went this route was that it was far easier and cheaper to find a 5 series donor than 3 series.
Hope this helps!
Simon
Old 8th March 2011, 21:36
Glen
The 3 series E36 ratios are different, as is the final drive:
1 = 4.23
2 = 2.52
3 = 1.66
4 = 1.22
5 = 1.00
Final drive =3.15 using 185 x 65 x 15 tyres.
This is probably more to do with the difference between the M20 engine and the M50, (I think the M20 reaches peak power at higher revs than the M50),
I have calculated that with a 3.38 Sierra diff, and 205/65/16 tyres I can achieve almost identical gearing as on the donor 3 series BMW.
Chris Cunliffe initially used a 3.62 diff with his M50, but found 1st gear was useless (too short, and set off in second), so changed to a 3.38: he is using 205/55/16 tyres.
Simon chose 215/55/17 rim/tyre combination, which have an increased rolling radius and compliment his 3.92 diff.
By carefully matching the engine characteristics, gearbox, final diff ratio and the rim/tyre size you can achieve the type of car/performance you want .
