Old 12th June 2005, 22:36
Tim Tim is offline
Tim is on a distinguished road
Default Fitting the calipers
Anyone got any ideas / come across this themselves.
My rear calipers dont fit. There is a 1cm gap between the caliper mounting bracket and the "ears" on the Marlin upright if the caliper mounting bracket and the caliper are to fit around the disc. I have double checked but the disc seems to be correctly fitted on the hu. The hub is tight into the bearing (any closer and it fouls the upright and the bearing is correctly fitted in the upright with the circlip in place.
Cleary I could just pack the gap with washers / custom shim - but is this OK?
Old 13th June 2005, 09:20
limpabit's Avatar
limpabit limpabit is offline
That's my next job so will be able to let you know in hopefully the next couple of days. I hope there all ok as I've just painted them all up!!
Old 13th June 2005, 12:55
Ex-Biker Ex-Biker is offline
I asked Mark @ Marlin this a while back.
'Pack 'em out with washers' was the answer.
I must empathsise though. To people that have built before, things like this are (apparently) more obvious than to new builders.
Good luck
Mark
Old 14th June 2005, 17:04
dylanp dylanp is offline
dylanp is on a distinguished road
Yup... Washers definitely do the trick...
1200 miles on the clock now and the brakes are getting better and better...
Dylan
Old 14th June 2005, 20:05
limpabit's Avatar
Is this the same for the front as I have space for washers at the front also!! Does it need a spring washers to mount the carrier?
Old 14th June 2005, 20:29
Default brakes
I had some issues with rear brakes, my donor being 25 model and the driving flange from the front now fitting to the rear meant the rear disc did not sit over the centre of the driving flange. I don't know whether this is just 25 donor or all 200 series. If I had realised before pressing in the bearings etc I would have had the driving flange modified to suit standard discs. I unfortunately only found out afterwards which meant I had to modify the discs to fit. I would just ask fellow builders to ensure that the discs sit all the way back onto the driving flange, not that easy to be absolutely sure, I ended up using a run out guage to make sure the discs were running true. I think I required one or two washers to pack the calliper mountings. I don't remember having any probs with front end.Brian.
Old 15th June 2005, 11:34
limpabit's Avatar
It might be me then trying to use the wrong bolts. They seem to be M12 bolts to hold the carrier on.
Old 16th June 2005, 20:31
John,
I'll add pics of my install to your list mate!
MarlinTurbo
Old 16th June 2005, 21:01
limpabit's Avatar
Cheers John.
I think I may have stripped the thread on the carrier. After painting them up as well!! Either that or there very very tight even with WD40. It won't go in anymore but still not fully home. There was not a lot of bolts that size left from the donor so assumed these was the correct ones. And the fronts are supposed to be the easy ones!! Maybe a trip the the scrappies this weekend to get the correct bolts and carrier if needed. Not sure if the carriers/calipers are the same across the Rover Range but just bought brand new discs and pads based on a 220 Turbo Coupe 1993!!
God help me when it comes the the rears!!
Ha ho
