Old 19th September 2010, 09:55
Steve Green Steve Green is offline
Steve Green is on a distinguished road
Default Rear disc brakes Ital - Dolomite Sprint
I am currently looking at doing a rear disc conversion on an Ital back axle (on the car) or a Dolomite Sprint axle (needs converting etc)
Has anyone here done this to an Ital?
Any suggestions please......
Old 7th June 2011, 21:24
Cat7 Cat7 is offline
Cat7 is on a distinguished road
James Whiting used to do this conversion for live axle Caterhams, might be worth giving him a call.
http://www.jameswhiting.com/
Old 8th June 2011, 07:00
Thanks for that, but when I spoke to James Whiting they were no longer supplying the kit as there was no demand.
I had a Marina and Sprint axle in my garage and with a bit of work I have fitted an MGF rear caliper and disc to both. The MGF uses the same wheel pcd so all I needed to do was fabricate a caliper bracket and sort out the hydraulics and handbrake.
I have only driven the Sprint modification and I am pleased with the final result.
Incidentally my Marina based Marlin also has larger front vented discs fitted, these came from a pretty common Renault setup.
