Old 2nd May 2020, 09:00
Ah, glad to hear that they fit.
Adaptors for TR's 2 to 6 are all the same, covering widths from 4" to 5.5" and look to be the same as the new ones you have (apart from the PCD) -
http://shop.mwsint.com/product_details.asp?id=564
https://www.revingtontr.com/engine-t...re-wheels/tab1
The longer ones you started with are a bit of a puzzle, do they fit the splines on your wheels and do the same spinners fit both?
Old 2nd May 2020, 11:33
deggsy deggsy is offline
Yes to both questions they came as a complete set with the wheels I only discovered the problem when I had the car jacked up to bleed the brakes?
Old 19th May 2020, 13:53
I think they must be earlier ones off the 15"x 5 wheels? £50 plus p&p if anyone wants them.
I managed to get a few jobs done lately I bought a new battery as the small racing one wasn't suitable for this I had to re-locate the battery and make a new tray.
But it didn't work out the way I wanted it as I had used the last of my alloy sheet and couldn't get any more I bit the bullet and bought one.
I have made a alloy clamp just to be safe.
As you can see in the photos I also had to re-locate the washer bottle.
That's it for now keep safe everyone.
Old 20th February 2021, 12:29
Wow haven't been on here for some time so thought I better give a quick update. i could'nt get the cluch to work so the engine came back out I fitted new clutch pivot pin and bushes and new a pushrod. whilst the engine was out i dropped the sump and fitted oversised crank thrust washers + 0.05 that sorted the crank end play engine back in and now i have a clutch again I am now trying to figure out which DVLA dept to send my built up vehicle report to as they can be a bit funny about that if it goes to the wrong dept they may send it back with an IVA application form not what i want.
Old 20th February 2021, 16:04
Good afternoon the form V627/1 goes to
K and R
DVLA
SA99 1ZZ , good luck Geoff .
Old 20th February 2021, 17:48
Ok thanks
Old 27th February 2021, 05:55
Deggsy - Good luck with the DVLA.
Is there much left on your 'To Do' list?
Old 27th February 2021, 08:40
Paul um no and yes the brakes need bleeding, not to bad. But just did a compression test yesterday after putting the engine back together and it is horrible 175. 135. 95. 90psi not good, it's running but will have to come back out at some stage. after I get everything sorted with the DVLA.
Old 28th February 2021, 11:16
Default progress so far
This is the progress so far
Not very good photos sorry.
and this is the offending engine.
I had my suspicions about the engine so last year i bought a short block from Chris in Honiton it had been re bored and I had the crank reground.
at this stage now the unleaded hed will come off the other engin as will the flywheel with it's pre-engaged starter. I will get that done after i sort out the changes with the DVLA
Old 2nd March 2021, 09:05
I had a phone call yesterday from a very nice lady at the DVLA saying the application is going through fine she was just cheking on what I wanted the car to be called. I should have the logbook back next week fingers crossed.
Old 2nd March 2021, 09:35
Sounds like a birth certificate !!
Old 2nd March 2021, 10:38
Yes just a bit the log book should read Triumph Tribute A352 if it all goes to plan!
Old 4th March 2021, 14:51
Default log book
Way hay log book went through ok it now says Triumph Tribute A352 and only took just under two weeks .
Old 4th March 2021, 15:26
molleur molleur is offline
Congrats!
