8th May 2018, 08:09
Big Cheese
I managed to get to Stoneleigh on the Sunday with the wife. First time in a number of years. Figured if the show is going to be any good again then it would be now with the weather so good. Wasn't disappointed, lots of cars on display (the outside club areas are the best bit of the show for me). Saw Alex's car and got some pics for the website.
You've done a great job on your Formosa Gary, hats off to you . Looks good in photos and close up looks even better. Lots of work has gone into getting a smooth look body finish, not easy to achieve but results speak for themselves. I really hope it takes off for you
Cheers, John
8th May 2018, 08:14
Thank you JG ...
So many people say it looks better in real life , I guess you see the detail and shape better than in a picture ...its a difficult car to photograph , the colour rarely shows correctly , its the same colour as Jeff H's car , but you wouldn't know that looking at most of the pictures ...
2nd September 2018, 20:59
Had a great today on the Cotswold Classic Car run, nice 80 mile drive around the Cotswolds 100 cars in total, Lucky enough to win best dressed gentleman and car so well chuffed
2nd September 2018, 21:11
Fantastic Alex .... f'kking brilliant ...
2nd September 2018, 21:49
Beautiful! Great work.
4th September 2018, 20:47
A few more photos from the Cotswold Classic Car Run
4th September 2018, 21:00
Thank you JG ...
Photo from eye level and using a longer focal length (ie not wide angle) usually gives improvement, can't change the colour balance though , but maybe do-able with computer?
8th September 2018, 05:44
Alex – Congratulations on your prize Graham.
Your car looks right at home here:
Enjoy, Paul.
17th November 2018, 15:19
After a bit of advice chaps, thoroughly enjoying the Formosa and been out in it pretty much every weekend throughout the summer and its great but the only thing I would like to improve is the top end speed.
Engine is the Vitesse 2.0l straight 6 but it seems to be struggling at about 4000 - 4500 revs (70mph) it feels as though its air or fuel starvation as the engine seems to have plenty more to give but feels restricted. The carbs are twin Stromburgs but they are a bit worn, I bought a replacement parts kit and a 7mm reamer but it just fell in the bore so lots of wear. my question really is has anyone put tripe SU`s or triple Webers onto a GT6 and does it increase performance, acceleration through the gears is great its just top end that is lacking. I want to get it on a few track days next year but a bit nervous its not quick enough and I would just be a rolling road block
17th November 2018, 16:48
It might be worth going through everything to rule out any restrictions that might be in the system. On my 250 TR project I'm replacing the fuel line that was fitted in the donor car as it was just 3/16 bore tube. I'm going to up that to 8mm tube which is the same as the fuel pump inlet. Have you got any tight bends or small tubing on the exhaust side of things ? Are you running a points ignition or electronic ? The older systems need to be 100% to work at their best. Points, condensers and coils can cause issues.
Once everything is checked perhaps a rolling road session to set up the carbs and ignition set at their optimum under load. You should see some gains with a carb upgrade but only if the rest of the engine is in good health.
Its also worth bearing in mind that the straight six was only rated at 95 BHP @ 5000 rpm in the early Vitesse and 104BHP @ 5300 in the MK2. Have you got the overdrive gearbox fitted, it might be down to a gearing issue perhaps ?
Good luck sorting it.
18th November 2018, 06:18
Originally Posted by Alex
… I want to get it on a few track days next year but a bit nervous its not quick enough and I would just be a rolling road block…
Sorry I can’t help with any engine tuning advice, so just a quick word on track days...
From my experience on two wheels, the person with the fastest bike didn’t always have the fastest time.
So whatever happens, just enjoy your day.
18th November 2018, 07:52
Apologies if I'm teaching you to suck eggs, but I'd start by making sure everything's set up correctly and not worn out.
Decoke the head and lap the valves in, then refit the head with a new gasket and check your compression - if it's below 120psi across the board or there's more than about 10psi difference between any cylinder it'll need a rebuild.
Assuming it's okay, fit a new cam chain and make absolutely sure your cam timing and valve clearances are perfect. Fit new or rebuilt carbs with heat shields (to prevent fuel evaporation) and a new or reconditioned distributor together with an electronic ignition module, new coil, leads and plugs. Set the ignition timing to 6 degrees btdc, fire it up and see how it feels.
Assuming everything is working as it should and you still want more power, I managed that with a Mk2 Vitesse cam and 1.75 Strombergs on adaptors. My motor had been going flat at 4500rpm and returning less than 20mpg, but those mods freed up the revs and gave around a 50% improvement in fuel economy to boot. It still wasn't a ball of fire but it was quicker and much more fun to drive.
For track use you really need to go large and/or modify. Phil J's green Spyder runs a 2.5 TR5 motor with a hot cam and six bike carbs. It pushes out close to 200bhp and has been clocked on the track at over 140mph (with 3.63 diff and overdrive). It also lapped faster than both a Porsche 911 and a Lotus 11, whose owner had laughed at Phil's car telling him the aerodynamics would make it too slow for him to compete with his Lotus.
I believe Phil posted on here that he could put another six carb setup together if anyone wanted one, but that was a while ago so you should pm him if you're interested.
Unless they're worn out, just changing the carbs for bigger ones or more of them won't make a dramatic difference without changing the cam and modifying the head. Witor would be a good starting point for parts and advice (other Triumph specialists are available) - https://www.chriswitor.com/products.php?cat=254&pg=2
Good luck and keep on enjoying your car.
18th November 2018, 10:47
Few words from a triump forum
MK 2 head is the way to go just because the 6:3:1 is an off the shelf component - 10.5:1 comp - TR5 cam and Strombergs - 150 bhp easy
was getting 180 bhp out of a mk1 block running on PI with 1500cc lada pistons - rev'd very well
19th November 2018, 21:03
Thanks for all the replies guys, plenty to ponder, don,t want to break a lap record just a bit of extra top end.the engine is a 1968 mk2 so possibly the TR5 cam and strombergs would be the easiest.Think I will get it on a rolling road and see what the restriction is and go from there
21st November 2018, 09:31
Watching this with interest - hopefully getting mine on the road in 4 to 6 weeks and may be afflicted with a dose of upgrade-itus ;-))
21st November 2018, 10:32
I would go with injection for a steady performance.
21st November 2018, 17:29
Hi Ray, good to hear the car is coming along well, getting close now
22nd November 2018, 20:52
Received a couple of photos today from Castle Combe that they took during the summer action festival
23rd November 2018, 08:09
Very cool indeed.
28th November 2018, 08:35
Cool dude !
